![]() Join Date: Jan 2010
Rubber seal for outer axle -Spindel seal kit?
I started putting back my dana 44 front axle and there is a rubber seal than goes onto the outer axle that needs replacement. What would this piece be called and would any know where to purchase it? It didn't seem to be listed in LMC but I am not sure what its called to search for it. Would it come with the spindle seal kit? I am assuming it does.
Thanks Last edited by 67gmcstepside; 10-09-2010 at 07:17 AM. |
Re: Rubber seal for outer axle -Spindel seal kit?
Axle seals or hub seals?I just did a front pinion seal on my 73 K 20, I was surprised when pep boys had it in stock. I would expect a Napa to have them and the parts break down to identify the seals you need.
1Rocky |
NAPA ng, the guy had no idea. Might try PepBoys. Every now and then I get lucky. It looks the the part I need is part of the spindle kit. It slips on the the axle and goes around the flat -round part end of the outer axles.
NAPA spindle kit is SBK-1
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Spicer Spindal Bearing kit comes with that seal and a trust washer(hard plastic) plus bearing = 706527X
I have not try to buy that for many years but that was the number I have in my notes...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Thanks guys, my kit is on its way. Once I have that seal I can finish up the rebuild and get it under the truck.
