Old 10-07-2010, 12:05 AM   #1
Shawn5488
Big block timing?
What are you guys with big blocks running for timing? I am talking about high idle timing, as in max timing. I set the timing at 32* like all the old muscle car forums said and the motor did not like it, simply sounded like to much, spark knock when hot at WOT, I turned the timing down and it seems happier but I just don't know what a good number to run is.
In the GMPP catalog I see the lower HP 454's don't run as much timing as their big HP motors so I feel like I am on to something. Thanks guys!
Shawn5488 is offline   Reply With Quote
Old 10-07-2010, 01:13 AM   #2
nbpro
Re: Big block timing?
15 initial 36 total should be in the ball park. Just listen out for any detonation while driving and if you are getting any now you may want to try it at 34 degrees total with vacuum advance disconnected
nbpro is offline   Reply With Quote
Old 10-10-2010, 01:19 PM   #3
Shawn5488
Old 10-10-2010, 02:01 PM   #4
PRattenbury
Not all big blocks are created equal. Depends on chamber size, compression ratio, spark plug heat range, fuel octane rating, etc. I don't worry about numbers. I use my ears and set it to what makes the engine happy.
PRattenbury is offline   Reply With Quote
Old 10-12-2010, 01:11 AM   #5
nbpro
well lets hope you don't have an earache next time you tune your motor
