Old 10-11-2010, 09:11 PM   #1
dmgibbs
1966 chev short bed
I have a 1966 Chev short bed and want to put disk brakes and a new rear end on it.
I have found a 1972 GMC long bed that I think i can use for parts.
What I need to know is will the rear end bolt up to my 66 without cuting and welding and will all of the other parts work..Front cross member,Power brakes,Automatic trans crossmember, drive shaft?
Any comment will be helpful.
dmgibbs is offline   Reply With Quote
Old 10-11-2010, 09:29 PM   #2
CVA59
Re: 1966 chev short bed
http://67-72chevytrucks.com/vboard/s...ght=disc+brake
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 10-11-2010, 10:14 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Thumbs down Re: 1966 chev short bed
Look around in the Suspension section.
There is alot of info there.
The front stuff is a basic swapping of parts, plus adding the disc brake master cylinder and proportioning valve from the '72.
The rear will be a direct swap also as long as both trucks are either coil or leaf sprung.
Keith
Convert to disc brakes.
Old 10-12-2010, 01:21 AM   #4
BarnFind
None of the later suspensions are a direct bolt up. They are not a difficult swap but still need a little massaging. The front will need at least a few new holes and a brake line modification and the back will need a little welding to make it work with truck arms. Sean
BarnFind is offline   Reply With Quote
Old 10-12-2010, 07:50 AM   #5
lolife99
lolife99's Avatar
Is this true, if both trucks have coil springs?
I'm trying to learn something here.
The Suspension section covers this topic in great detail.
(My answer was a quick overview).
The front can be done without changing the crossmember itself.
(a-arms out, parts swap)
Brake lines go with the M/C swap.
If the OP has a donor truck,... I would think he would have everything to to the swap.
Keith
Old 10-12-2010, 10:23 AM   #6
BarnFind
You are exactly right, maybe I jumped the gun a little. The first post stated a "72 GMC donor" and I assumed leaf spring truck. My bad. Sean
Old 10-12-2010, 10:43 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
You are exactly right, maybe I jumped the gun a little. The first post stated a "72 GMC donor" and I assumed leaf spring truck. My bad. Sean[/SIZE]
Good observation, but you have to remember not "all" GMC's came with leaf springs, just as not "all" Chevies came with coil.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-12-2010, 11:01 AM   #8
BarnFind
Here I thought, half ton GMC,......... leaf spring truck. The things you learn on this site! Sean
Old 10-13-2010, 12:59 AM   #9
Captainfab
60-66 Nut
It also depends if the GMC donor is a C10 or C20 whether the parts are going to work for the OP. If it is a C10 and has rear coils, it should be a straight forward swap. You will have to shorten the driveshaft though. That usually doesn't cost that much to have done.
Old 10-13-2010, 10:24 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Oh yeah, almost forgot! Welcome to the forum.
Articles-
"Refining Sierra"
Old 10-14-2010, 09:43 AM   #11
BarnFind
What year did GMC 1/2 ton go to coil springs? Sean
Old 10-14-2010, 10:08 AM   #12
LT1 Burb
LT1 Burb's Avatar
I sold a 72 GMC SWB last year and it had coil rear suspension.
LT1 Burb is offline   Reply With Quote
Old 10-14-2010, 11:41 AM   #13
blacklistcustoms
blacklistcustoms's Avatar
I believe it was 64 when GMC went to leaf springs
66 c-10 swb stepside -my daily driver
74 1Ton CrewCab Shortbed 4X4
(2) 91 2500 suburban 4X4
91 K5 Blazer 4X4-wifes daily driver
73 K5 Blazer 4x4- project soon to be 2wd
50 3 window 3100
blacklistcustoms is offline   Reply With Quote
Old 10-14-2010, 11:44 AM   #14
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Just to clear this up. Chevy's had coil spring rear suspension Standard and leaf springs Optional. GMC had leaf springs Standard and coil springs Optional. The year ranges from '63 (maybe from '60, I am not sure on the torsion bar frames) to '72. In '73 they all went to leafs in the rear and prior to '60 they were leafs front and rear.
Hope that helps.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-14-2010, 11:49 AM   #15
markeb01
Senior Enthusiast
markeb01's Avatar
My 1960 GMC 1/2 ton short bed came stock with the coil spring/trailing arm rear suspension.
Old 10-14-2010, 11:44 PM   #16
blacklistcustoms
I was aware of the earlier and later models not sure on 60-72. Most 61-66 chevys we've had were all coil and the one 65 GMC was leaf all were 1/2 tons 2wd. figures GM would offer the same options mirrored for the trucks. Thanks for the clarification.
50 3 window 3100
