Old 10-08-2010, 05:31 PM   #1
mdazb
mdazb's Avatar
Window rubber DIY
I'm getting ready to replace the window and vent rubber in my 72 C10. Are there any DIY w/pics? Shortcuts? that you guys can add before I jump into this?
Thanks in advance
Mark
72 C10 SWB 350 Work in progress
98 HD Fatboy
09 HD Heritage Softail
05 Honda Element
mdazb is offline   Reply With Quote
Old 10-08-2010, 09:35 PM   #2
Sammy
Re: Window rubber DIY
Lots, lots of patience. Do a search for a thread someone just posted some ideas in the last month with pics. Do NOT remove the PIVOT RIVET is my only advise. Everyone I've heard of that removed it was sorry they did.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-11-2010, 01:34 PM   #3
mdazb
mdazb's Avatar
Thanks for the reply.. I'll do a search to see if I can find it.
Looking for step by step instuctions ( do this first, do this second)..
98 HD Fatboy
05 Honda Element
Old 10-11-2010, 09:47 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
http://67-72chevytrucks.com/vboard/s...ad.php?t=90510
LockDoc
Leon
Old 10-12-2010, 12:01 AM   #5
mdazb
mdazb's Avatar
Thanks for the link, Actually I need that info as well. Should've been a little clearer. My bad.
I'm starting the side window channal, vent wing rubber replacement etc. Basically rebuilding the doors. That's the info that's needed now. Still searching posts. Any help would be great.
98 HD Fatboy
05 Honda Element
Old 10-12-2010, 08:08 AM   #6
NC67Chev
NC67Chev's Avatar
Here's a couple of threads for you:
http://67-72chevytrucks.com/vboard/s...t=vent+windows
http://67-72chevytrucks.com/vboard/s...d.php?t=351471
http://67-72chevytrucks.com/vboard/s...d.php?t=153937
I just finished rebuilding a set for my '67, and it really wasn't that bad. I removed the pivot rivet and didn't have any problems getting the new one set. After reading the many threads, the things that I found to help me most are as follows:
1) When removing the vent assembly, remove the rear window track mounting screws. This will allow you to slide the window back, which will make getting the vent assembly out very easy.
2) Get someone that is willing to help you for the process of rebuilding the windows.
3) You must start with the front corner of the vent rubber first. Using dish soap for lube, get the angle portion of the rubber started in the track and sliding it forward seemed to be the easiest way to get the rubber started. Then you can simply use dawn and a flat screwdriver to work the rest into the track.
I think if I rebuild them again, I will try to use pop rivets for everything except the pivot rivet. The biggest thing though is to take your time, do one at a time so you have a reference, don't start into it until you have plenty of time, and walk away for a few minutes if you get frustrated. I hope this helps!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 10-12-2010, 10:59 AM   #7
mdazb
mdazb's Avatar
Perfect,, Thanks brother.
98 HD Fatboy
05 Honda Element
Old 10-15-2010, 02:04 AM   #8
project67-stepside
project67-stepside's Avatar
just did mine with the lmc rubber it was easy, drill out the rivets......
it usual better and faster if u figure it out yourself!!!!
project67-stepside is offline   Reply With Quote
Old 10-19-2010, 05:39 PM   #9
mdazb
mdazb's Avatar
Did you use pop rivets or the LMC rivet kit? I have both, just want to see which is better
98 HD Fatboy
05 Honda Element
