![]() Join Date: Oct 2007
Big Block Heat Shield Measurements with Pictures
These are my measurements and pictures I took from the Heat Shield I have for my 402 BB.. I added a drawing along with them for anyone who would want to build thier own as I know they are hard to find and I have seen lots of requests on the forum for measurements ..so thought I would share.. I will be glad to answer questions regarding these pictures and the drawing measurements,,,,,,Gopapa Larry
![]() ![]() ![]() ![]() ![]() Thanks to (68 50th forum member) here in these two pictures show where the heat shield goes This shows the bolt holes location right next to hump on firewall down where the rear of the manifold will be when the motor is installed ![]() This shows a heat shield all bolted up in it's proper place behind the exhaust manifold ![]() Last edited by GOPAPA; 10-12-2010 at 03:59 PM. |
Re: Big Block Heat Shield Measurements with Pictures
Good info !!!
72 Cheyenne Super 80 Silverado Blazer 2wd |
Where does this shield fit on the engine, and what does it shield from heat?
Ray |
Ray,
It bolts to the floor board on the big block trucks and is there to shield the right side manifold heat from the passenger compartment. The manifold comes real close the angled part of the floor board. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thank you, Jim. I would never have known, unless maybe I installed a BB and my floor mat started smoking!
Ray Last edited by raycow; 10-11-2010 at 09:53 PM. |
Thanks for this information. I appreciate it.
A couple more pictures to show where this heat shield goes..thanks to { 68 50th }Member from Sweden..
the pictures are added to the first group in the first posting ..above ^^ Last edited by GOPAPA; 10-12-2010 at 04:05 PM. |
