Old 10-11-2010, 11:33 PM   #1
enick72
enick72's Avatar
T5 speed sensor to cable drive
Has anyone ever coverted a manual trans with speed sensor to cable drive. I got a really good deal on T5 but is has a speed sensor. Is there some kind of conversion that can be done or would I need to change the tailshaft housing and internals?
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 10-12-2010, 12:01 AM   #2
halfcockedcustoms
halfcockedcustoms's Avatar
Re: T5 speed sensor to cable drive
would would have to change the ail housing and internals,,,,I went the cheap/easy way and just got a cheap GPS for my truck
halfcockedcustoms is offline   Reply With Quote
Old 10-12-2010, 04:12 AM   #3
raycow
Have you removed the speed sensor from the transmission yet? If not, please do so and see if it is gear-driven.
Ray
raycow is offline   Reply With Quote
Old 10-12-2010, 06:31 AM   #4
lucifer
lucifer's Avatar
Try these guys...they will have an answer for u
http://www.speedometersolutions.com/...eter_cable.htm
lucifer is offline   Reply With Quote
Old 10-12-2010, 12:51 PM   #5
enick72
enick72's Avatar
Ray
I have taken it out and it just had a tone ring for the sensor. I was hoping for a gear driven sensor. I have found adaptors to make cable drive to sensor but not the other way.
Thanks for the link lucifer, I sent them a message,
55 Chevy 1st series
Old 10-12-2010, 03:39 PM   #6
TR65
TR65's Avatar
One solution is a CableX motor drive for the speedo. Works good but not cheap. See the thread below.
http://67-72chevytrucks.com/vboard/s...d.php?t=416110
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 10-12-2010, 05:05 PM   #7
raycow
I agree completely about the Cable-X (price). Unless you need to keep a totally stock dash appearance, you can run an aftermarket electic speedo for less than half the cost.
Ray
