Old 10-12-2010, 04:12 PM   #1
hotrodimpy
Lokar Performance Products. Needing some help
We am looking for a section of firewall from a 1967-1970 C-10.
The last time I posted needing a section from a 71-72 the responce was great. If anyone can help with this please contact John Impy at Lokar.
Toll Free 1-877469-7440 I can explain what section I need.
Thank you John
hotrodimpy is offline   Reply With Quote
Old 10-12-2010, 05:43 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Lokar Performance Products. Needing some help
Do you mean a picture or the actual physical firewall?
Member Nr. 2770
Old 10-12-2010, 06:02 PM   #3
hotrodimpy
I need an actual firewall
Old 10-12-2010, 11:05 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
here you go....
Member Nr. 2770
Old 10-13-2010, 10:31 AM   #5
MudBug
MudBug's Avatar
You need everything or just the sheetmetal? If non of the boys up your way can't find one give us a call.
MudBug is offline   Reply With Quote
Old 10-13-2010, 10:57 AM   #6
hotrodimpy
Not having much luck this time. I need only the sheet metal. From inside the truck. I need from just left of the 4 bolts that mount the master cylinder to 24" to the right of that. Should be into the trans hump. From just above tha master cylinder down 24". The area that I am intrusted in is where the throttle pedal mounts and enough area around it to hand some pedals as a referance to each other. Thank you John (865) 966-2269
Old 10-13-2010, 11:40 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
As a purchaser of several Lokar items, including the Eliminator gas pedal, I'm interested in what Lokar has in mind for our trucks. Don't have my gas pedal installed yet, so a new product may be easier to install.
Member Nr. 2770
