Closed Thread
Old 10-13-2010, 07:41 PM   #1926
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: What did you do to your truck today?
Amazing how you can wake up one day with an obvious solution to a what was a very complicated situation. Looks good Mark!
aerotruk63 is offline
Old 10-13-2010, 08:48 PM   #1927
lakeroadster
Lookin' good Mark, and you didn't even have to crawl under the truck! Those types of projects are great, come up with an idea, make the part and install it in a short time frame. Congrat's.
I spent the day starting to remove old paint and bondo from the bed rails and rear fenders of my truck. The top of the bed rails had over an 1/8" thick coat of bondo... removed that with a 4" electric grinder and a wire wheel.
Using a paint stripping disc to remove the paint. Works pretty well, noisey and dirty though.
Soooo, some people actually like body work? This is my first real try at it in the last 30 years.... I am assuming it will be more "fun" once I can start finishing, instead of striping.
lakeroadster is offline
Old 10-13-2010, 09:12 PM   #1928
aerotruk63
aerotruk63's Avatar
Have your box blasted, start fresh. Let someone else dirty their shop.
Old 10-13-2010, 10:32 PM   #1929
scooterskoolkustoms
scooterskoolkustoms's Avatar
got my new roll pan in the mail today so I cut out the old bumper and started to fit it on my burb I'll weld it in and take some pic's.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 10-14-2010, 12:29 AM   #1930
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
well my flywheel busted and pulled my torq out its socket and busted my 700r4
i drop so many f bomb my back yard looks like japan lmao
i took it to the shop so they can redo the clutches.
i cant shft out of 1st
maybe another 300 sent down the hole
Sick5 is offline
Old 10-14-2010, 09:32 PM   #1931
Turkey
Turkey's Avatar
Replace my old vacuum advance and fuel line with stainless lines. Also got my new mig in today. Gotta go get some gas tomorrow and weld my cherry bomb in!!
Turkey is offline
Old 10-15-2010, 04:38 PM   #1932
Bugeyev8
Bugeyev8's Avatar
Got my newly repaired hood on and test fitted and got the interior almost prepped for paint...lots of sanding and sanding....should spray it on monday if I can get the repaired doors hung and aligned
Bugeyev8 is offline
Old 10-15-2010, 09:55 PM   #1933
SRVBLUES64
Friday 15th finished up back of cab with the bodywork, now on to the top of the cab, theres several hail dent mark some are hard to see cause I stripped the can down to bare metal so its all by feel. Im wondering if I can giude coat with a aresol primer? or should I just spray my epoxy primer and then look for low spots? Im hoping to get primer on the can before winter kicks in, any thoughts of what I should do if I cant get primer on it?
SRVBLUES64 is offline
Old 10-15-2010, 10:52 PM   #1934
daverod
SSN 706
daverod's Avatar
Hate to tell you this but I don't think primer is water/weather proof?
daverod is offline
Old 10-16-2010, 01:26 AM   #1935
markeb01
Senior Enthusiast
markeb01's Avatar
In my experience there's nothing better than epoxy primer for protecting bare metal. And it sticks so tight you can do body work over the epoxy. If the metal is going to be indoors protected from moisture, you can just spray it with Picklex 20. It will keep bare steel rust free indefinitely, but only if it remains dry.
http://autobodystore.com/picklex20.shtml
Standard aerosol primer is generally lacquer, is not waterproof, and makes a poor substrate for anything put on top. It is commonly used as a guide coat, but the best results will be achieved if all of it is sanded off. Then there is no risk of incompatible materials under the finish.
markeb01 is offline
Old 10-16-2010, 08:37 AM   #1936
willyp
willyp's Avatar
sand blasted the ash tray and painted it, made a trim piece to cover up the hack job around the radio face and mounted my speakers in the vent openings in the kick panels.
The price of cool aint cheap.
willyp is offline
Old 10-16-2010, 04:25 PM   #1937
Andice
Andice's Avatar
Started to paint the rear half of the frame today in preparation of the bed install. I did all I could with the big brush. A smaller brush next week should just about wrap up this phase. It should take at least a week for the Por-15 to wear off of my hands.
Andice is offline
Old 10-16-2010, 05:34 PM   #1938
SRVBLUES64
didnt get much done I got hit with the why isnt this done yet why do you statr something and never finish it yikes Pms, here in Indy you have do what you can do when the weather is good in October, I hope Sundays good, oh yeah Im off Monday and tuesday. has for my last question on Priming, my truck sits inside the garage during winter, and stays dry, should I still prime it ?
Old 10-16-2010, 05:36 PM   #1939
knuckledragger
knuckledragger's Avatar
Set the 402 in and started mocking up the engine mounts.I am using the captured style 73-87 mounts.I also made sure the headers will clear.I will definitely be using an electric cooling fan.
knuckledragger is offline
Old 10-16-2010, 05:56 PM   #1940
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
We pushed sams60gmc down the road...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 10-16-2010, 07:48 PM   #1941
knuckledragger
Mounts are mocked up!Will remove engine tomorrow and finish welding them up.
Old 10-16-2010, 08:08 PM   #1942
CVA59
Got the old rockers off and geeeezzzz what a rusty mess that was.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline
Old 10-16-2010, 08:46 PM   #1943
bigdaddy64
bigdaddy64's Avatar
Cut the top off today to clean up the rust, add some sound deadener, knock a couple dents out and weld top back on minus drip rail. This is the last of my rust repair!
66 c20 with 1/2 ton 73-87 front and rear suspension
2-1/2" drop spindles, air-bags, c-notch rear frame
463 Pontiac, SRP Pistons, Eagle Crank and Rods
Mega-Squirt Fuel Injection
bigdaddy64 is offline
Old 10-16-2010, 09:25 PM   #1944
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Well I finally got back to playin with OLE BLUE this weekend. My new to me toy, '93 Blazer, has had my full attention for the last month. Anyway, I took the rearend cover off, cleaned everything up, checked my gears & put in new 85W140 gear oil. I also sanded, primed, painted & put my swaybar on the front. I bought it from one of our members a while back as my truck didn't come factory with that option. After cutting out one of the crossmember rivets it bolted right up. Man I Love my '69!
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline
Old 10-16-2010, 09:34 PM   #1945
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Daydreaming about my day at the shop tomorrow....Stuck here at work for my Friday.
fryer1979 is offline
Old 10-16-2010, 11:20 PM   #1946
sams60gmc
sams60gmc's Avatar
Well like my good buddy Frenchblue72 said. We got a good idea and pushed my frame over to his house, about 3 blocks away with one pretty busy intersection in between, when it got there we put the cab on the frame had to do some minor trimming to clear where the frame goes down for the body drop. Then we pushed it back to its home. Lays rocker no problem.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 10-16-2010, 11:47 PM   #1947
markeb01
Senior Enthusiast
markeb01's Avatar
Disassembled my throttle linkage looking for a problem, and discovered a fractured nylon spacer. Replaced it with a steel version, which restored the normally smooth operation.
markeb01 is offline
Old 10-17-2010, 08:51 AM   #1948
lakeroadster
YOUR KILLING US GUYS, WHERE'S THE PICTURES! HOW COOL WHOULD THAT BE TO HAVE A PHOTO OF YOU PUSHING YOUR TRUCK THROUGH THAT BUSY INTERSECTION! OPPORTUNITY LOST!
Old 10-17-2010, 09:26 AM   #1949
aerotruk63
aerotruk63's Avatar
Do it again!
Old 10-17-2010, 10:10 AM   #1950
FRENCHBLUE72
PROJECT 7DEUCE
heres some pics from my cell phone that he wife took as she helped push once in awhile...
MEMBER #6377
Project "7DEUCE"
Closed Thread
