10-13-2010, 08:30 PM | #1 |
lower control arm shaft need help
alright so i took the upper and lower arms off my 86 dually. i replaced the upper ball joints and painted the arms everything is fine there. On one of the lower arms i can grab the shaft and spin it freely, but i cannot move it side to side. should i just try and tighten it or do i need to rebuild it? i have it all apart and i dont mind rebuilding it so now is the time to do it.
1987 Gmc sierra 1962 Apache 10 |
10-13-2010, 11:18 PM | #2 |
Re: lower control arm shaft need help
If the nuts on the shaft ends are loose or removed, this is normal. If they are tight, you have a problem with the bushings.
Ray |
