Old 10-14-2010, 10:33 PM   #1
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Re: Halfbreed - GMC Z71 + IH Extd Cab
That's right. So then a center belt section from a square-body (73-87) with a bench seat should do perfectly...if they were longer. One idea is most auto parts stores stock those seat belt extensions, most I've seen are about 10" long or so. Another suggestion is the aftermarket lap belt assemblies. IIRC they are quite long, are offered in a few basic colors, work as a stand alone unit, and are fairly inexpensive. Again, any local auto parts store should stock them at about $25 or $30 (maybe less, it's been a while since I last purchased some). For a junkyard score, how about pre-87 Chevy fullsize vans? Or maybe an early lap/shoulder combo, and just cut off the shoulder strap? Just throwing ideas out now...good luck with the belts.
fryer1979 is offline   Reply With Quote
Old 10-14-2010, 11:18 PM   #2
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
You could use your fabric seat belts and order some seat belt webbing, then take them to a upholstery shop and have them sew them back up to the length you want. Look here http://www.strapworks.com/Polyester_Webbing_p/sbw2.htm though there are several other places to order it from.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
