Old 10-16-2010, 12:22 PM   #1
enick72
enick72's Avatar
Re: '54 4 speed question
The good thing is that it's not much effort. I bought a T5 for my 55 but put it in my 65 since its more of a daily driver and the process is pretty easy and they are usually found fairly cheap. I'm no expert by any stretch but I have heard that the torque tubes are not a very good design to begin with so you may be better off going with an open drive line.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 10-16-2010, 01:38 PM   #2
ofnaman
ofnaman's Avatar
What would I get a t5 out of? also, what is required to make it fit?
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 10-16-2010, 02:38 PM   #3
Dan Bowles
AD Addict
S10 or Camaro. You might try a search. There a lot of them done. There is a whole thread of putting a T5 behind a 235 on the HAMB and I'm positive there is info here, you just need to do a bit of research.
You will need to do some clutch disc investigation as well as that for cross members. I've had a majority of the parts 2-3 times but have ended up selling the truck or the car before I got to it!
Dan Bowles is offline   Reply With Quote
Old 10-16-2010, 04:17 PM   #4
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Interestingly a current model Corvette uses a torque tube. Its more complex but from an engineering standpoint the approach has some real advantages.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
