Old 10-12-2010, 10:51 PM   #1
7D2N
7D2N's Avatar
Pillar Fender Seals
I got my new dust seals and just wondering if anyone has a picture of them installed,the drawing in my assembly manual shows location but still not sure about the two small hinge pieces. pictures show the kit I have and the metal pillar sides that get stapled.
7D2N
7D2N is offline   Reply With Quote
Old 10-13-2010, 09:49 PM   #2
7D2N
7D2N's Avatar
Re: Pillar Fender Seals
Anyone installed these? the drawing from the assembly manual shows this application but not real clear for the small pieces.
7D2N
Old 10-13-2010, 10:05 PM   #3
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
Where did you get the kit from?
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino.
Stay Tuned!
1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD!
09 GMC Sierra SLT All Terrain pkg.
2014 Jeep Wrangler Sahara unlimited. ( The wifes ride )
GobbleStalker is offline   Reply With Quote
Old 10-14-2010, 02:01 AM   #4
Billhilly
Billhilly's Avatar
I've always wondered how do you put those big staples in? Anyway I am a ways off from trying yet! Here are some shots I took on disassembly. Don't really show alot to be honest!
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 10-14-2010, 05:27 AM   #5
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
I did mine recently, got them at Classic Parts. Most people on here were saying that these were such a PITA to install and the end result and benefit made it not worthwhile...I tend to agree. I ended up just installing the two large pieces, there was no way I had the tools to fix those large staples so I just used the self taping hex head screws to fix them onto the metal bracket, then fitted the bracket with seals attached back to the body, but then the cut out ends that sit over the door hinges didn't line up so I had to trim them and the final holes to fix them to the body also didn't aline...the small separate pieces went in the bin were they belong
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 10-14-2010, 08:54 PM   #6
7D2N
7D2N's Avatar
8 your probably right with the small pieces, I'm going to put them back to stock the best I can.
Old 10-14-2010, 08:58 PM   #7
7D2N
7D2N's Avatar
Thanks Billy, that will help a bunch. I have a couple of ideas for the stapling part.
7D2N
Old 10-14-2010, 09:11 PM   #8
7D2N
7D2N's Avatar
Classic Industries. looks like they will work great for 72, just a little fitting and what not should be good to go. I'll update when I get them stapled.
7D2N
Old 10-14-2010, 10:37 PM   #9
71 super
71 super's Avatar
Dont use the staples they give you with the shields. Go to lowes or depot and get some staples to use in putting up insulation etc. The staples they send do not fit the brackets if you will look in assembly manual in the 1970 section I think there is a better diagram of the actual assembly.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 10-17-2010, 03:30 PM   #10
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I used the staples that came with the kit. I used a small drill bit to drill through the existing staple holes and into the shields. Then I pushed the staples through and bent them over with a pair of wire cutters to get the bend started, and them hammered them over. Took about 10 minutes to do the set.
Zoomin is offline   Reply With Quote
Old 10-17-2010, 03:46 PM   #11
Billhilly
Billhilly's Avatar
To easy huh Zoomin! At least you are around to figure this stuff out for us.
1972 K2500 Long Box
400/350
Old 10-27-2010, 10:56 PM   #12
7D2N
7D2N's Avatar
Well I finished up the pillar dust seals, thanks for the responses it helped a lot. Zoomin the way you suggested is the way I ended up doing it after a few failed attempts.
7D2N
Old 10-28-2010, 04:14 AM   #13
Billhilly
Billhilly's Avatar
Great job 7D2N. I can copy you now, I just hope my memory doesn't completely fail by the time I get to do mine!
1972 K2500 Long Box
400/350
Old 10-28-2010, 11:50 AM   #14
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Glad it worked for you. I was tempted to blow off putting them on, but since mine had them I wanted to put it back that way. I'm not sure what good they do, but what the heck.
