Old 10-18-2010, 02:47 AM   #1
Zonaman
Zonaman's Avatar
D'ohh!!! Drove with parking brake set!
OK true confessions time. I was at the lake and always set my parking brake (69, drim brakes rear) on the ramp when launching and recovering the boat. Not that it does me much good because the rig would still roll if not in park, with it set, just more slowly. Anyway I managed to drive about 12 miles before I stopped. You could sure smell them (no visible smoke) and the drums were as hot as a steam iron when I stopped. No signs of fluid on the outside. Let them cool for about an hour and went on with no apparent problem.
What should I be looking for when I get around to inspecting them?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 10-18-2010, 05:17 AM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: D'ohh!!! Drove with parking brake set!
cracks in the brake lining is sign that they got pretty hot, if they are it is probably time to get some new shoes. If everything looks good then you just need to adjust the star nuts so that the brakes engage when you set the parking brake.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
