Re: What did you do to your truck today!
I havn't done this listing "what I done to day" much ,,but today I made headway and feel like telling all ...I have every thing I ever done to my truck written down with the amount of time and the cost of every nut and bolt .. I installed battery cables ,put heat wrap around the starter,,and wrapped heat shield around gas line next to Manifold ,,drilled holes and hung the heat shield to the fire wall,,hooked up heater hoses ,,hooked up power steering hoses, screwed in tranny line fittings into the tranny and hooked up the lines to the radiator,,plugged the clutch hole in the fire wall .
Tried fitting up the modulator tube but it sure doesnt look it is the correct one so will go back to the wrecking yard and find another..
getting closer to crank up.. yahoo I guess is in order..LOL
