Old 10-18-2010, 08:36 PM   #1
drsergio
drsergio's Avatar
How to lower a 1969 GMC truck ? ( front )
Just got a very original 1969 GMC 2wd truck with a stock 6 cy shift on the col
Lots space on the front and I would like to lower maybe 4 inches or so
Any kits or any suggestions?
Would like to do without making the ride hard
Thank You for any pictures or links that You can send
ty
drsergio is offline   Reply With Quote
Old 10-18-2010, 08:44 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: How to lower a 1969 GMC truck ? ( front )
4" on mine. Cut the coils, a-arm kisses the bumpstop. Rides better than most old trucks I've ridden in.
or you can buy springs.
or you can buy springs and spindles.
get a swaybar! Won't lower the truck any but improves driveability 100%
don't forget to get an allignment.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-18-2010, 10:18 PM   #3
red69ss
Burnouts are therapeutic
red69ss's Avatar
are you going to lower the front and not the rear? if so 4 inches is going to be a lot of rake.... deffinently get drop spindles plus springs for your desired drop if you want more than 2 inches,if it has drums on the front they don't make drop spindles for drums to my knowledge. a lot of guys on here use ECE http://www.earlyclassic.com/ for suspension and thats who I plan to use also.good luck and nice looking truck
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 10-18-2010, 10:56 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
GET A SWAYBAR DIY OR A KIT!!!
Then, depending on how low/and how much $ ya wanna spend..
Cut 1 loop off your stock springs then get an alignment
Get drop springs then get an alignment
Drop spindles and no alignment NEEDED but prolly a good idea if ya aitn got one in awhile...
Or a combo
John
1999 Toyota Tacoma 4x4
Old 10-19-2010, 09:46 AM   #5
drsergio
drsergio's Avatar
Thank you for the ideas,,,If I just wana lower like 2.5 ,,,,or maybe 3 ,, Can I just get drop springs then get an alignment
looks like changing the spindles will be away to much for me ,,,look at this link,,,,,huge job ,,,,but perfct teaching tool
http://67-72chevytrucks.com/vboard/s...d.php?t=354132
Old 10-19-2010, 10:06 AM   #6
coryalexander
man changing the spindles is not that hard, you can do it. you have to pretty much take the spindle off anyway to change the springs/cut them . i would lean towards changing spindles and do a little cutting on the springs verse just cutting springs. you will still have alot of suspension travel with the spindles and it would ride better(hell in that case just like it rides now.
and it wont hurt to put disc brakes on it, much better brakes to make sure you are safe.
coryalexander is offline   Reply With Quote
Old 10-19-2010, 10:50 AM   #7
pat 70/71
pat 70/71's Avatar
I would change the spindles and front springs to get the height you want. (not that hard)and since your there, change out the ball joints. ( also not that hard) IMO, this is worth thinking about. that way you are good to go! cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 10-19-2010, 02:56 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Check out my build thread in my signature (Project Blank Slate) and it is everything you will need to know about lowering your '69.
I installed 2.5" drop spindles matched with 2" springs upfront; upgraded to 6-lug disc brakes and then lowered the rear with a 6" drop spring. New shocks on all four corners and shock relocators in the rear.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
