Old 10-18-2010, 12:24 AM   #1
newbraunie
newbraunie's Avatar
Solenoid wiring question
I am cleaning up some wiring in the engine compartment. The purple wire that runs from from the fuseblock/firewall to the solenoid is currently routed through the firewall gutter- to top of motor right side along intake manifold/valve cover down front of motor to solenoid. Is this how this wire was run from the factory? Did it come with fabric insulation? The insulation is cracked from heat and I need to replace this wire.
newbraunie is offline   Reply With Quote
Old 10-18-2010, 05:38 AM   #2
JimKshortstep4x4
Re: Solenoid wiring question
That is the routing for the purple wire to the starter solenoid. The wire was originally covered with plastic and not fabric. The original wire is 12 gage and if you are replacing it you may want to increase the size to 10 gage.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-18-2010, 10:53 AM   #3
hayhauler71
hayhauler71's Avatar
I ran mine down the backside of the cylinder head to the starter a lot closer less heat and resistance
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-18-2010, 09:03 PM   #4
newbraunie
newbraunie's Avatar
I think that is the route I am going to run it.
