15" rally rims on a 92
I bought a 1986 Silverado 4x4 for parts which had new 31" tires and 6 lug Rally rims. Since I needed tires and rims for my 1992 K1500 I trial fit them last night. The only issue I have is that there is a small interference with the rim and the outside sliding edge of the caliper. The pads are new so the caliper is at the extreme outward position. I touched the edge of the caliper with a grinder and the interference went away. The tire offset looks nice. Has anyone else used the 15" Rallies on a post 87 truck?
Chris
Re: 15" rally rims on a 92
tons of ppl run 15 inch rims on 88-98 trucks, some have problems with the calipers others do not. I seen guys run the 2wd rallies onthe 2wd trucks but not alot of 4x4 rallies.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
I'm running the 2WD 5 lug ralleys on my 90, with Astro van center caps. I have the 6.5" rims upfront with lowered spindles and had to clearance the lower control arm.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
I seen a truck on the board that has them. Might of been a blazer but they looked good.
If it ain't broke broke don't fix? Get a hammer. '89 K1500, Reg. cab/long bed, 350/700r4, 285/75-16. |
I put the Rally tires and rims from the 86 parts truck. I did a little grinding on the outside of the calipers to round the edges for clearance.
I need to install the body patch panels and install the 86 rebuilt transmission and it will be a nice running truck for a 92. |
Old Skool Club
![]() Join Date: Jun 2001
You wrote that like an eighteen year old truck is on its' last legs.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
laying low
![]() Join Date: Mar 2001
Those rallys help the looks of most anything you put them on.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Looks good on that 4x4! I have them on my bagged and bodied '95 and they look like crap lol.
Posted via Mobile Device |
Always trouble
I had some painted body color on my 91 2wd step-side, they looked bad @ss IMO.
91 Silverado Regular cab, 2wd, swb-project truck 97 Silverado Extended cab, 2wd, swb-driver |
Painted? Sounds nice, but my trucks gonna be a satin black so painted wheels wouldn't really add more color lol. Mine need painted, 2 are spraybombed black and 2 are rusty so that adds to the ugly lol. Maybe some paint and new rings would be nice.
I run them sometimes on my 96 4X4, but the tires are only 9.25 inches wide, and I had no clearence issues.
1982 K10 SWB 1987 V20 - Sold - Doh! Last edited by TwoFiftyShifter; 10-19-2010 at 09:47 AM. |
It's been awhile but I did have a Rally's with the mid 90's bowtie center caps and it really didn't look bad at all. My truck has a 4/6 drop kit on it so I had the van rally's (15x6.5)up front and 15x8's on the rear. I did have to grind the corners of the brake calipers down a bit to clear the inner wheel lips though.
Paint 'em RED, that's the hot lick with satin black!
I rember grinding on my brand new 1989 to get those 4x4 rallies on there.Everyone at the tire store thought I was crazy for taking a makita to a brand new truck!Whish I had that one back.
| Bookmarks |
