Old 10-14-2010, 09:55 AM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Ram horn to header: Altenator/Pwr Steering brackets?
I am putting a set of headers on my truck. The engine is out right now and I was looking at my ram horns and noticed there are mounting bolts on it. What has everyone used to replace these once the headers are on?
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 10-14-2010, 12:59 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Ram horn to header: Altenator/Pwr Steering brackets?
My '69 has holes for mounting, in the head. Reckon that's the issue with older heads.
I remember seeing some brackets that bolted on with the headers, that created the mounts for the accessories.
Member Nr. 2770
Old 10-14-2010, 01:15 PM   #3
Zumo
Hot Rods For Life
Zumo's Avatar
I'll have to check the heads. The truck has been sitting since 2003 and I am gathering parts to get the engine back in. I just need to set it in the truck and just start putting things on it to see what I'm missin.
Andy
Old 10-14-2010, 02:29 PM   #4
ERASER5
ERASER5's Avatar
Do you have a 327? Most of the original 327 heads that I have seen, do not have mounting holes. 283's either. Looks like fab time.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-14-2010, 03:20 PM   #5
Zumo
Hot Rods For Life
Zumo's Avatar
No the original motor was a 307. That one died. I now have a 77 350 with 350 heads. I guess I need to look at my heads and figure out what year they are.
Andy
Old 10-14-2010, 03:36 PM   #6
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
What waterpump setup are you gonna use? I have the short style waterpump and I used an aftermarket chrome alternator bracket setup that mounts on the #1 primary of the header, then for the ps pump I made an spacer out a stack of washers and hooked that to the front bolt of the header along with the alternator mount (kind of ghetto, but I'm planning on making a real spacer out of pipe sometime). Here are some links to the two alternator brackets similar to mine (you bolt the first one onto the header, then bolt the second one onto the first one, then mount the alt. on the second one....if that makes sense )
First one (mount to header)
second one (alternator actually hooks to this one)
Hope this helps and makes sense.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-14-2010, 04:08 PM   #7
Zumo
Hot Rods For Life
Zumo's Avatar
Thanks Jac! This is the info I was looking for. I will check my water pump when I get home tonight.
Andy
Old 10-14-2010, 04:43 PM   #8
Jacfourteen
No problem. I forgot to mention you will also need this if you don't have one already. Good luck.
Old 10-15-2010, 10:55 AM   #9
Zumo
Hot Rods For Life
Zumo's Avatar
Yeah I went to the site and noticed it required those. I think mine will work.
I got to work on it a little last night. I installed my harmonic balancer and discovered I need new valve covers so I think I will order the covers adn these brackets at the same time.
Andy
Old 10-19-2010, 05:12 AM   #10
283_c10
283_c10's Avatar
I used the Mr. Gasket alternator bracket set, and it works well and also looks good. Got the entire set on Ebay for $15.
283_c10 is offline   Reply With Quote
