#76 | |
Re: 65 C60
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#77 |
Re: 65 C60
Guys,
I've got a 68 c-50 with split rim "widow makers" on the rear axle. The tires are 8.25 x 20. What rims can I replace these with, nobody here in Utah will touch them. Can I use the existing tires I have with innertube on the new rims? If anyone has done this before please give some input |
#78 |
Re: 65 C60
I'm not sure you're going to find a 20" wheel for that bolt pattern. We got semi-truck 22.5 steel wheels and Bridgestone V-Steel semi tires. Cost $1k, but we'll never need front tires again.
#79 |
Rods
![]() Join Date: Nov 2002
Re: 65 C60
you could have or can get 22.5 alcoa aluminum simi wheels and have them turned down to 22. then u can get street tires in 22.
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
#80 |
Re: 65 C60
That would be even more expensive. Our wheels were $250 apiece as were the tires. I'm sure Alcoa alum's are $500+ apiece. Plus, it's on a C50 anyways, he's going to want the load capacity of the semi tires. It does have the large 5 bolt pattern, correct?
#81 |
Rods
Re: 65 C60
they sell adapters on egay for them to go to 10 or 8. you can call Goodyear of someone like that. they are not that bad at all or the local salvage yard(big truck) they sell them also. When i worked at penske I think I could get them for 150 200 each. I was going to do this for my dad on his 73 one ton. dully
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) Last edited by 70 Suburban; 07-09-2009 at 10:36 PM. |
#82 |
Re: 65 C60
local truck tire garage had semi rims that fit it like a glove. 3 of the 6 tires are now on the upgraded rims. I'll swap the last three when the tires wear out.
#83 |
Rods
Re: 65 C60
sweet
#84 |
Re: 65 C60
We were told on the rear that if/when we have to replace one rear tire, we have to replace them all, as they can't re-mount these wheels apparently. The rears have tons of tread, so I hope we don't get a flat, lol.
#85 |
Jonny
Re: 65 C60
I wish those pics hadn't dissappeared....
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
#86 |
Re: 65 C60
Oops, I moved them in my PB. I'll fix the links, as well as add some new pics.
#87 |
Re: 65 C60
Pics Updated. Also hauled 2 loads of scrap with it in July. First was gates out of hog barns, and they weighed almost 6 tons, hauled another load of 3 tons of steel. About $600 of steel at $75/ton.
#88 |
Re: 65 C60
wayyyyyy late (as usual) but hey the thread came back to the top so I looked in.
Nice truck..excellent score!!!!! You don't see many in THAT good of condition. Wish I had that cab. Wait... I wish I had the whole truck!!! |
#89 |
Jonny
Re: 65 C60
yeah! I got to see how nice your truck is. I'm kinda on the hunt for one right now as my plans for my profect change whenever I see something I like. Now I've got it in my head to get on of these beasts to use as a base for my crew cab build. How cool would one of these be with a crewcab, big window, cummins, and a 10 speed? And it would have to be set up with air suspension and a fleetside bed with step side fenders added one....oh, and the bed would have to dump, can't have a big truck w/o a dump bed....anybody wanna sponsor this?
#90 |
Re: 65 C60
Haha. Umm, this truck is staying here....
#91 |
Resident of Here
Re: 65 C60
Pics of it now?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck
#92 |
Jonny
Re: 65 C60
I've been cruising the net for one and saw a wrecker with a BBW! I didn't think they ever made heavy duty trucks like that. Anyway I'm on the hunt now, just might make a kill. If you have a minute can you measure from the back of the cab to the front of the rear wheels? I'm woondering how much room is in there.
#93 |
Re: 65 C60
Every truck is different, depending on the bed that was put on. GM made one chassis and the coach builder cut and welded in frame extensions to make their bed fit.
Tito, the only thing different that you can see on the truck is the wheels, and right now it's in the shed, behind a bunch of tractors. If I get it out to change the oil before winter, then I might get some pics.
#94 | |
1961 crewcab
Re: 65 C60
check out www.6066gmcguy.org/ for frame length for the bigger series trucks, there were quite a few. .... and check out this for inspiration
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#95 |
Jonny
Re: 65 C60
That's some pretty awesome inspiration. I've got to thinking about this since I've already seen a couple crewcab c10's running around the forum, which would make mine be another in the crowd. I've also thought of doing a Long Bed dually
#96 |
Re: 65 C60
does anyone have a manual know anything about a schwartz t60 hoist ????? a manual for one would be great
#97 |
Re: 65 C60
I have a 1965 c60 dump with that model hoist, and the company is out of business and having a real problem locating any literature on the hoist
#98 |
Senior Enthusiast
Re: 65 C60
Edit - posted in wrong area.
| Bookmarks |
