Old 10-19-2010, 07:24 PM   #1
rennalds
rim size??
found some nice rims on craiglist i want just am not sure if they will fit my 1971 c10??
size of rims:5x4.75 +20mm 6.225" bs
any help would be appreciated
rennalds is offline   Reply With Quote
Old 10-19-2010, 07:54 PM   #2
rennalds
Re: rim size??
Old 10-19-2010, 08:08 PM   #3
DrtyJack75
Re: rim size??
I BELIEVE you need a 5x5
DrtyJack75 is offline   Reply With Quote
Old 10-19-2010, 08:18 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: rim size??
Chevy trucks with 5 lugs are 5x5. Cars are 5x4.75. Unless someone used a kit to put the car pattern on (unlikely), those wheels will not work. Also, the BS is way too deep. Now you could run adapters that not only space out the wheels so the BS would work, you could convert to the 5x4.75 pattern. Figure about $150 or so for adapters. So unless the wheels are a screaming deal and exactly what you want, I would pass on them and find the right wheels.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
