Old 10-20-2010, 02:01 AM   #1
Woodbutcher
Woodbutcher's Avatar
uugh! Squeaky bushings
I am assembling my front end right now. The tubular control arms from TCI came with preassembled bushings. I assemble it once already, but took it apart after noticing how much they squeaked and squalked. I know you need to use a silicone based lubricant on the poly, but how on earth do you get it in between the bushing and the steel sleeve when it is a preassembed unit from the factory? Any ideas anyone??
If the women don't find you handsome, they should at least find you handy... Red Green
Keep your stick on the ice, Woodbutcher
Woodbutcher is offline   Reply With Quote
Old 10-20-2010, 10:42 AM   #2
Atomsplitter
Atomsplitter's Avatar
Re: uugh! Squeaky bushings
I had the same problems with my cab bushings.
After some WD40, a little grease on the ends and about a year mine quieted down.
Its too bad that the manufacturers didn't put a grease fitting there for you.
Atomsplitter is offline   Reply With Quote
Old 10-20-2010, 11:21 AM   #3
OrrieG
OrrieG's Avatar
Doesn't over lubrication defeat the purpose of using the urethane bushings (move stiffness and less movement in the suspension)? Maybe a animal seringe and liquid silicone based lube will work?
