Old 09-02-2010, 10:07 AM   #226
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: 1969 Chevy Stepside Restoration/Build up
nice progress
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-05-2010, 11:59 PM   #227
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Originally Posted by my67chevytruck View Post
nice progress
Thanks!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 10-14-2010, 02:55 AM   #228
matthew20061
69' Chevy Stepside
Re: 1969 Chevy Stepside Restoration/Build up UPDATED 10/13/2010 Winter Projects
Well forgot to post up these pictures of it....
-Matthew
Old 10-14-2010, 03:00 AM   #229
matthew20061
69' Chevy Stepside
BIG NEW and UPDATE!!!!!
Now here's the "big news and update" for the truck, I've bought a 6.0L LS Engine from a 2004 Cadillac Escalade, it's an LQ9 (has factory flat top pistons and some other internal stuff). But it doesn't end there, to top off the LQ9 its going to be woken up by a new set of L92/LS3 Cylinder Heads with Stainless Steel Intake and Exhaust valves, Patriot Gold Dual spring rated at .660 lift, and a new 2010 Camaro LS3 intake mainfold!!!!
Pictures of the Junkyard running LQ9, its clean!
-Matthew
Old 10-14-2010, 03:03 AM   #230
matthew20061
69' Chevy Stepside
Original factory heads are off the LQ9, and the pistons are all cleaned up! Next the engine block will be prepped and sanded down and painted Copperhead the color of the truck.....
-Matthew
Old 10-14-2010, 03:05 AM   #231
matthew20061
69' Chevy Stepside
All the new parts!!!
-Matthew
Old 10-14-2010, 03:08 AM   #232
matthew20061
69' Chevy Stepside
New ARP Head Bolts and ARP Intake Manifold Bolts from JEGS got here today, the other parts I got last week. Also since the L92 heads use a different valve spacing you need special L92 intake rocker arms and supports, but you can reuse your existing exhaust rockers.
-Matthew
Old 10-14-2010, 03:13 AM   #233
matthew20061
69' Chevy Stepside
The LS3 intake manifold comes complete with factory 42lb injectors but they use a different connector type which is a USCAR/EV6 connector type so I bought the pigtails off ebay so I can rewire my existing harness.
-Matthew
Old 10-16-2010, 06:24 AM   #234
matthew20061
69' Chevy Stepside
UPDATE:
Painted the engine, the Copperhead color of the truck and it turned out looking awesome. Now I'm going to pull the oil pan, front cover, and valley cover and sand blast them and clear coat them! Should set it off a bit, if the bare clear coated aluminum doesn't look right I'll find a nice gray color for them.
Check the pictures out....
-Matthew
Old 10-16-2010, 08:43 AM   #235
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like christmas is coming early this year nice score..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-16-2010, 09:25 AM   #236
1LoC10
Insert Title Here
1LoC10's Avatar
Awesome truck
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 10-19-2010, 12:41 PM   #237
matthew20061
69' Chevy Stepside
Got the heads all assebled last night! Lapped the valves in and they where ready to go! Pics:
-Matthew
Old 10-21-2010, 12:40 AM   #238
matthew20061
69' Chevy Stepside
Head gaskets came in! The new comp cam will be here tomorrow!
-Matthew
Old 10-21-2010, 01:02 AM   #239
67chevylongbed
67chevylongbed's Avatar
Awesome progress! Lovin' the new motor..
Eric
1967 C10 LWB SOLD....
1995 Ford F-250 4x4 Powerstroke, 342k
"Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known."
-Ronald Reagan
67chevylongbed is offline   Reply With Quote
Old 10-21-2010, 03:17 PM   #240
matthew20061
69' Chevy Stepside
Thanks!
The new Comp cam and Pushrods came in from Comp Cams. There website said they would only ship free to the lower 48 but I choose free shipping anyways and it still gave me free UPS ground shipping to Alaska. Haha
-Matthew
Old 10-22-2010, 09:07 PM   #241
0_71chevy
nice truck i love a new style LS motors easy to make power with and reliable! That copperhead block looks slick too.
0_71chevy is offline   Reply With Quote
Old 10-23-2010, 03:10 AM   #242
matthew20061
69' Chevy Stepside
Thanks!!!
I just got the new cam installed but have to wait to put it together since I don't have the timing chain yet.
-Matthew
Old 10-24-2010, 04:46 AM   #243
matthew20061
69' Chevy Stepside
Installed the New HD Timing Set from Yank......
and I sand blasted and painted the Front Cover, Oil Pan, and Valley Cover.... turned out awesome!!!!
-Matthew
Old 10-25-2010, 03:23 AM   #244
matthew20061
69' Chevy Stepside
Installed the New awesome L92/LS3 heads, bolted them on with the new ARP fasteners and Felpro gaskets. They definitely set off the copperhead block and the nice gray colored aluminum parts I painted with High temp engine paint and high temp clear coat.
-Matthew
Old 10-25-2010, 06:00 AM   #245
trenz68
Damage Inc
trenz68's Avatar
nice...me likes
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
Old 10-25-2010, 11:14 AM   #246
mcbassin
Still Learning
mcbassin's Avatar
That engine looks great! Thanks for sharing all those pics!
Old 10-26-2010, 02:54 PM   #247
matthew20061
69' Chevy Stepside
Originally Posted by trenz68 View Post
nice...me likes
Thanks guys!
I Got all the valvetrain installed into the heads, had a problem with one of the rocker arm bolts somehow it got stripped out even though the heads where new. I tried to tap it out reinstalled the bolt and tried to torque it but as soon as I tried to tighten it the threads pulled out of the head. So I had to helicoil it, but it all worked out and now its all installed.
-Matthew
Old 10-26-2010, 09:30 PM   #248
matthew20061
69' Chevy Stepside
Ordered a new Corvette Power Steering pump to replace the leaking factory one. Hopefully the truck will be leak free after the motor swap.
-Matthew
Old 11-03-2010, 09:34 PM   #249
matthew20061
69' Chevy Stepside
Ordered a Circle-D Converter 278mm, 3200 Stall speed. I'm guessing it should be here next week hopefully. After it gets here I'm ready to start pulling the 5.3L and replace it with the 6.0L!!!
-Matthew
Old 11-04-2010, 01:13 AM   #250
matthew20061
69' Chevy Stepside
Latest pics, I just test set/fit the intake on there to see how it would look and dang!!!
-Matthew
