Old 10-19-2010, 06:28 PM   #51
pickup67man
pickup67man's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
I like the crew cab idea but I already have trucks. I am trying the 4 door suburban idea. Looks like you have helpers for your project. Hope my daughter wants to help when she is older. She is 2 1/2 right now and doesn't like dirty hands. I'll be watching your build.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 10-19-2010, 09:09 PM   #52
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Travis,
Just read your build, great work. Can I cut the 4th door section out of your burb????
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 10-20-2010, 12:18 PM   #53
68 TT
Still plays with trucks
68 TT's Avatar
You have me thinking impure thoughts about my neighbors Suburban.
Great project. Can't wait to see it done.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 10-20-2010, 05:39 PM   #54
drewskiren
drewskiren's Avatar
Next up is a trial fit. First I was going to use the floor of the truck cab also, but when I got to cutting on the Burb I found a nice steel plate in the spot I was going to have to build a kick up. It already is raised 6 inches, so I'll just use that and lop off the truck cab bottom. So far it looks like it will fit. Notice I had left everything long to decide later how best to mate each item. The pass side is easy because both vehicles wrap their quarters onto the jamb. I simply drilled out the welds on both and wrapped the cab corner like the factory did. I kept the blue drivers jamb side just in case I decide in a few years I am ready to tackle the 4th door option. It'll give me something to do on the truck after I'm finished and start to get bored. I also have seen plenty of unfinished projects for sale because the guy just gets overwhelmed. I'm going to try and avoid that!
Drew
Old 10-20-2010, 06:33 PM   #55
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Old 10-20-2010, 06:39 PM   #56
68 TT
68 TT's Avatar
Originally Posted by drewskiren View Post
....I kept the blue drivers jamb side just in case I decide in a few years I am ready to tackle the 4th door option. It'll give me something to do on the truck after I'm finished and start to get bored. I also have seen plenty of unfinished projects for sale because the guy just gets overwhelmed. I'm going to try and avoid that!
Wise choice. No need to get bogged down with two major projects all at once. Just creating the quad cab is a big enough project but adding in creating the 4th door setup at the same time is likely to be overwhelming.
Like you said, you can always go back after the truck is on the road and do the work to install the 4th door.
Old 10-20-2010, 08:34 PM   #57
sourkraut
sourkraut's Avatar
very cool build!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 10-20-2010, 08:50 PM   #58
76kcfdeng
Awesome work! I don't think I could get through what your doing without giving up and selling it. I love crewcabs, I am looking forward to seeing the finished product.
glen
70 Chevy SWB Fleet Project.
06 Lancer Evolution MR SE, stupid fast!
03 Ford f-250 crew cab, 6spd, diesel
56 ford f100 project
My build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=426739
76kcfdeng is offline   Reply With Quote
Old 10-20-2010, 11:43 PM   #59
extremesounds13
Great work! It's cool seeing it coming along.
extremesounds13 is offline   Reply With Quote
Old 10-20-2010, 11:51 PM   #60
67chevylongbed
67chevylongbed's Avatar
Cool build, looking great so far!
Eric
1967 C10 LWB SOLD....
1995 Ford F-250 4x4 Powerstroke, 342k
"Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known."
-Ronald Reagan
67chevylongbed is offline   Reply With Quote
Old 10-21-2010, 05:25 PM   #61
pickup67man
Travis,
Well it would be easy to cut out. Its not fully welded in yet.
Yours would be best to finish the cab first to set your dimensions. Then if you still want to put the door in it would be easy to copy the other side.
Travis
Old 10-22-2010, 09:37 AM   #62
drewskiren
drewskiren's Avatar
Remember what I said about leaving it long and make the final close cut later, yeah well the rear panel bottom edge was a close one. I think I've got 3/8ths to trim here.
See where the passenger quarter wraps the jamb? This makes it so easy to align and plug weld my drill outs.
If you're wondering, the plastic hanging is just to keep the rest of the garage a little less dusty when sanding/bodywork.
Drew
Old 10-22-2010, 10:18 AM   #63
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Dude you are really moving on this project..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-22-2010, 10:24 AM   #64
69CST-V
69CST-V's Avatar
NICE work. I'm hooked. You make it look so easy.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 10-22-2010, 10:41 AM   #65
sparkydog
sparkydog's Avatar
Great project and you are going at it the right way! It is weird that we have the same color combo going on our projects - just different ratios. I have a lot of blue, some white and a little patch of yellow!
Your MIG is about to get a nice workout!
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 10-22-2010, 10:51 AM   #66
suville
suville's Avatar
Heres a slide show of one built here in Meridian Idaho by Mark at Ace, hope it works not real confusor savvy.
http://www.aceautocustoms.com/curren...evy-truck.html
suville is offline   Reply With Quote
Old 10-22-2010, 01:36 PM   #67
drewskiren
drewskiren's Avatar
That is fantastic!!! Thanks for the link.
Drew
Old 10-23-2010, 12:16 PM   #68
drewskiren
drewskiren's Avatar
All I have to say is WOW. Like you, this is my first real welding job, I hope I improve along the way like you have.
Apparently we think alike with the modern drivetrain ideas, I won't be taking it as far as firewall and floor removal though.
Drew
Old 10-23-2010, 12:20 PM   #69
drewskiren
drewskiren's Avatar
Frenchie,
I have done all this work between Easter and May30th, about 8 weeks. I stopped for the summer. I am still getting everyone up to speed but I'll give you a hint, It looks reeeeally good now.
Drew
Old 10-23-2010, 02:05 PM   #70
drewskiren
drewskiren's Avatar
The first pic is how my cab back simply sits on the burb kick up plate. This works so well.
I have seen other guys bracing everywhere before they cut stuff apart, but I didn't bother. I had measured before and knew I would be making minor width adjustments anyway, so why fool with it. Once I got the rear of the burb cut away I realized how much of a waste of time braces would have been. The structure was still rock solid and it took considerable effort to tweak it into shape. I had to use a porta power ram to spread the cab back slightly and ratchet straps to pull the burb in. The straps were so tight I could have played a tune by strumming them.
Drew
Old 10-23-2010, 02:12 PM   #71
drewskiren
drewskiren's Avatar
Need to cut off the square door top on the third door, later.
Took a break from brain surgery and did a simple skin graft on the rusty floor spot. Everybody has seen this detailed before, so I won't really go into it.
Drew
Old 10-23-2010, 02:15 PM   #72
drewskiren
drewskiren's Avatar
OH YEAH, now we are cookin. Tons of measuring and even more eyeballing have me ready to commit. Time to put the scalpel away and start sewing this monster up.
Drew
Old 10-23-2010, 06:33 PM   #73
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I really like the way you are doing this one ...... Some really good ideas and it really looks like it's gonna pay choosing to start with such a good base vehicle ..... gonna save a ton of work not having to fix rust ! IMO you need to do the 4th door but I do see the value in waiting and getting the bigger project done, NICE work.
ksbrktracer is offline   Reply With Quote
Old 10-23-2010, 07:18 PM   #74
classicchev
classicchev's Avatar
I agree, a must on the 4th door. I know when I build one it will be a 4 door.
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 10-23-2010, 10:55 PM   #75
drewskiren
drewskiren's Avatar
Darren
I hear ya on the fourth door, but it is just too much for now. Much bigger issues to tackle with the rest of the build to pile that one on too.
Yes, starting with good clean metal and having to spend virtually no time on repair work is VERY, and I repeat VERY, nice.
Drew
