10-19-2010, 05:02 PM | #1 |
can i get some help with mounting my gearbox?
when i got my 64 the steering was completely apart and in a box. i got the centerlink and tie rods setup but im struggling with mounting the box, i think im missing something. the box wont mount flush to the frame horn and i just dont see how this could work. if you could post some pictures or maybee describe this better to me id apreciate it. i can post up pics if you need them.
1967 c-10-built smallblock, backed by m-21, lowered 2005 silverado-tint, exhaust, lift, 35's 1964 c-10 shortbed project |
10-19-2010, 05:06 PM | #2 |
Re: can i get some help with mounting my gearbox?
is it manual or powwer ?post a pic and let us take a look
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
10-19-2010, 05:10 PM | #3 |
i believe its a power steering gearbox, also the steering shaft has been lengthened i believe if that helps.let me get a pic or two up
10-19-2010, 05:29 PM | #4 |
If the power steering was added on by the PO you need adaptor plates. Do a search "power steering" you can find a pic hope this helps
10-20-2010, 12:03 AM | #5 |
60-66 Nut
If it is a power steering box you will need an adpater plate to space it out from the frame. This allows for the raised area on the backside of the box.
10-21-2010, 09:40 PM | #6 |
si all i need is a power steering mounting kit??
here is my truck here is my box and this is my setup on the 67 just as a reference this is what i plan on doing, a ps setup with no pump thanks again for any help
10-22-2010, 12:51 AM | #7 |
60-66 Nut
Yes you will need an adapter plate to mount that power steering box on your '64 frame. If I may ask, why do you want a power steering box if you're not going to connect it to a pump?
10-22-2010, 01:24 AM | #8 |
The Captain is right . Do yourself a favor click the Power Steering Box Adapter Plates For Sale HERE tab
under captainfabs sig buy it install it and forget !!
10-22-2010, 11:41 PM | #9 |
60-66 Nut
Thank You Sal
10-23-2010, 08:30 AM | #10 |
1 thing at a time is progress.
I'm wondering that also. PS with no pressure is harder to turn than a manual box.
Alan
Philippians 2:14-16 |
10-23-2010, 03:01 PM | #11 |
alright thanks alot when im ready to slap it all on il grab a plate from you captain
as far as keeping this box its just simpler that way the shaft has already been cut for it and i dont want to waste 200 dollars on a new manual box not to mention it doesnt bother me the setup in the 67s not that hard
