Old 10-23-2010, 04:51 PM   #1
PRattenbury
Identify an engine??
Stamped on the pad on the passenger side block deck is V1227WK. On the back of the block on the driver side, is casting 3932386, Name that motah!
PRattenbury is offline   Reply With Quote
Old 10-23-2010, 05:36 PM   #2
87GMCChris
87GMCChris's Avatar
Re: Identify an engine??
Googe is a wonderfull thing....
1969 3932386 350 4bolt LT1 from: http://www.nastyz28.com/sbchevy/sblock.php
3956618
3932386
68 - 79 350 & 302 250-300 4 bolt mains
Truck/Hi Perf from: http://www.thedirtforum.com/castings.htm
WK 1969 350 tur hydro - 255 4 C-10 to 35 from: http://www.nastyz28.com/gm-chevy-cod...-suffix-10.php
So from three sources... i would say you got a 1969 350, 4 bolt main. Unless it was changed internally
1987 GMC Wrangler - 305TBI/TH400/Duals
1968 Camaro - Resto
2010 Ranger
I only drive truck 6 months a year... Dam Canadian winters.
87GMCChris is offline   Reply With Quote
Old 10-23-2010, 05:41 PM   #3
87GMCChris
87GMCChris's Avatar
Comment withdrawn. Irrelevant.
1968 Camaro - Resto
2010 Ranger
Old 10-23-2010, 05:48 PM   #4
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Originally Posted by 87GMCChris View Post
Also, I would like to note that I have a rebuilt 327 that I bought from my uncle. When i ran my codes it came up as a 1969 350 2 bolt. So i asked him and he said he used the block with a 327 crank (350/327 blocks are the same). So if everything is stock i would say you got a '69 350 4Bolt. Hope this helps.
327 & 350 blocks WEREN'T the same. Small vs Large Journal. It's safe to say that SOME 327 / 350 blocks could cross reference, but only when the 327 crank was a large journal crank.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 10-23-2010, 06:19 PM   #5
PRattenbury
Cool! So I have a 350 4 bolt main block. It has flat top pistons in it. .060" stamped on them. Now, having said that, let me add some more flavor to the conversation. With the block, I also got a Comp Cams 268H cam, new still in the box. I have a GM tuned port intake setup. I'd like to use it, with the 268H cam. Nice thing about the TPI set up is, I can change runners, injectors, throttle body, and the tune (chip) to suit my needs. I also have my MSD 6AL box, blaster 2 coil, and Pro-Billet dizzy. Also, I haven't decided on a set of heads yet. I would like to go with aluminum heads. 2.02/1.60 valves, 64cc or so chambers. But these intake runner sizes confuse me. Looks like I should be less than 200cc? I have a 700R4 trans, 275/60R15 tires. I'm not sure about my gear ratio. But this is all for a 80 short wide truck. Use will be daily driver, back and forth to work, knocking around town. So I ask, does the cam seem like too much? What heads would you suggest? This is build the engine, part Deux. Part one was a fail. #1 cylinder is near death, engine is making rattling, angry noises. Old, worn-out 69 307 block was a bad idea to build. I had no idea it was that worn-out.
Old 10-23-2010, 09:43 PM   #6
PRattenbury
Nobody has any opinion on what cc runners I should look for in cylinder heads? No opinions on the cam working/not working with TPI? It's a Comp Cams 12-268-2. Also known as a XE268H.
Old 10-24-2010, 08:38 AM   #7
PRattenbury
Wow. No opinions. Okay.
