vent window install
I just installed a pass. side nos vent window and figured out a easy way to do it.
1. I had to install the lock lever first and this is easier than it seems just don't over think it. It is a very simple lock design. Pay close attention to how the 2 gaskets go in place. They kinda fit inside each other. I removed one old one from another vent window by driving out the roll pin carefully with a small nail and hammer and re-installed on new vent window. Also, put the window in first by getting the rear roller in the round spot in track then slide glass back until fromt one lines up with round spot in track. Now your ready for vent frame. The nos vent window only has 1 screw at top and 1 on the diagonal because later model Suburban's are the same unlike pickups that have 2 on the diagonal. I may try and put a second on it because I now have an unused hole or cover hole. I also have a Suburban driver's door that only has 1 screw. Take some 3/8" rope and make a clove hitch at top around vent window and door and put another near bottom of vent window and door. These knots when pulled tight will hold the vent window in place and allow you to pull it tight against door frame and as your doing this go around vent window pulling out rubber weatherstrip inside/outside where it goes. Take you time and slowly work it in place until top screw lines up. Put the top screw in first it is hardest to line up seems then front screw and finally the bolt in inside of door. The driver's side went in without having to pull it in place and it was not nos but original to the door. Last edited by HOGDADDY; 10-24-2010 at 08:09 PM. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: vent window install
submit this as a FAQ or write up it may help someone else in the future
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
How do I do that?
