Closed Thread
Old 10-24-2010, 04:43 PM   #1001
67Slider
67Slider's Avatar
Re: What did you do to your truck today!
Had a buddy come over and we welded the exhaust back up right after the camaro tank install. Good to go now. Shot some more paint on the bed sides this morning. One more touch up spaying and I will start cutting the wood down and fitting it in the bed.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 10-24-2010, 06:46 PM   #1002
csutter
Put new valve cover gaskets on to stop major oil leak, changed oil, couldn't get filter off though. Also replaced broken turn signal arm.
csutter is offline
Old 10-24-2010, 08:19 PM   #1003
Sonicman
Sonicman's Avatar
SQUAT........ I'm just waiting for Clifford Performance four barrel intake and dual shorty headers for my 250 inline 6. Man waiting sucks
Sonicman is offline
Old 10-24-2010, 08:59 PM   #1004
rsavage
rsavage's Avatar
Started tearing stuff out of the interior of the 71 Blazer I picked up. Removed rear seat and took out home made side panels and carpeting. Carpeting was glued down. Anyone know of a solvent that will aid in the removal of carpet adhesive. Paint thinner (mineral spirits) doesn't really do much.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline
Old 10-24-2010, 09:08 PM   #1005
lil hoodlum
lil hoodlum's Avatar
I painted my hood, drivers side front fender, and driver side door. I have been painting my truck for neary the last month. More of less piece by piece. I am in a rush to finish the exterior befor it gets to cold outside.
Keith
lil hoodlum is offline
Old 10-24-2010, 09:36 PM   #1006
pat 70/71
pat 70/71's Avatar
drove the wifey to lunch and put about 75 miles on it (in the rain) ran great good times! cheers, Pat
pat 70/71 is offline
Old 10-24-2010, 09:38 PM   #1007
willys72fleetside
willys72fleetside's Avatar
Talking Re: What did you do to your truck today!
Got my bed back on int time for winter. Painted the inside of the doors and got them rehung today. Trying to get things ready for winter so I can work on the bed body work and or the motor.
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline
Old 10-25-2010, 12:22 AM   #1008
60ratrod
yes, i do
60ratrod's Avatar
Ordered a gasket set and ez efi multi port retro fit kit for my 72. I actually ordered those last week when i found the kit in an ebay auction for $699. i can't wait to get the brake conversio done on the mrs's 72 maliu so my 72 can go in the garage for some work next
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 10-25-2010, 12:33 AM   #1009
mcmlxix
Collector of Projects
mcmlxix's Avatar
Swapped in a Red-Head steering box. Rebuilt the rag joint. Pulled the PS pump and ordered a new one alond with what I hope is the correct high pressure line....
I also unbolted the body mounts so I can install the new poly kit and 1" ORD body lift....
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 10-25-2010, 04:13 AM   #1010
shiner2001
shiner2001's Avatar
4" rear drop...woo hoo!! 2" front is ready to go in as soon as the front rebuild kit arrives from CPP.
And also, a trip to the car wash
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline
Old 10-25-2010, 04:46 PM   #1011
Shyguy
Junior Member
Shyguy's Avatar
Finally found a little time between other projects to work on the '71. I re-routed the wire to the temperature sending unit wire away from the headers.
Mounted the remote solenoid and figured out how to run the new wires.
While re-routing the temperature sending unit wire I noticed that the wire to the Hei distributor was spliced to the yellow wire. It has been running ok that way, but I decided to run a new heavier duty wire to the distributor from the ignition unfused connection in the fuse block with a in-line fuse.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 10-25-2010, 04:57 PM   #1012
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
relized that with Cupped LCA, 2 1/2" drop spindles, and a dropped X member not only would I have to get rid of my A/C and heat but the tire would be rubbing on the hood and firewall....Dam why can't it be easy to be cheap
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline
Old 10-25-2010, 05:42 PM   #1013
Beat68CST
Beat68CST's Avatar
Gettin ready to go back out and wire wheel the wheel wells and core support for paint!
Just got done cleaning up threads on all the bolts.
Also, gave my water pump to my motor builder.
I need to get this front end ready for my 327! Pronto!
Beat68CST is offline
Old 10-25-2010, 06:47 PM   #1014
crapy67
White wall terror
crapy67's Avatar
I just got done replacing my LMCrap wiper switch that was in the truck for maybe 6 months with a 40 year old GM switch that still works.
crapy67 is offline
Old 10-25-2010, 07:46 PM   #1015
68C10HotRod
68C10HotRod's Avatar
I had one of the same ones pretty much explode & come apart too. Replaced mine with one from another 72 truck also. The old one felt like it was 3x the weight as the new one.
On Sunday - did a temporary work around for a bad wire somewhere in the heater harness. Ran a fused line from the fuse box to a toggle switch at the cig lighter location & then on to the motor. On or Off at full speed is better than NOTHING. It's been a little chilly here some mornings & foggy windows are hazardous to drive with.
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline
Old 10-25-2010, 08:04 PM   #1016
yote1234
yote1234's Avatar
installed trim,headliner bumper,wireing, built doors.........
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline
Old 10-25-2010, 08:31 PM   #1017
yote1234
yote1234's Avatar
few more
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
yote1234 is offline
Old 10-25-2010, 11:40 PM   #1018
trkfrk
trkfrk's Avatar
I welded up my firewall and fuel inlet on my cab.. I ordered everything from Infanti machine http://www.infantimachine.com/products.htm. fit perfect. The gas filler hole was rolled perfect... It would have been cheaper to buy a sheet of metal but saved me a day of labor ($80.00 total with shipping). Highly recommend.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline
Old 10-26-2010, 05:07 AM   #1019
mcmlxix
mcmlxix's Avatar
I installed the power steering pump and new hoses.... filled and bled the pump and box.... its still on jack stands because I had to go to work ...
And the Red Head ....
Rich
Last edited by mcmlxix; 10-31-2010 at 06:28 AM. Reason: added pic because everyone loves pics
mcmlxix is offline
Old 10-26-2010, 10:28 PM   #1020
swamp rat
swamp rat's Avatar
Nothing except get a drill and tap together to install a ground line off my fuel cell to the frame, need a good ground hole on the frame.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline
Old 10-26-2010, 10:55 PM   #1021
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
My wife picked up our new one-piece drive line ($272 all rebuilt w/new yoke...I expected about $150, but I'm living in the past, I guess.).
Bolted up the new brake set up to the pedal (now the only thing left in the cab). Guess what, the '68 (the cab I'm using) pedal assy has the part that accepts the brake rod that goes through the fire wall about 3/8" shorter than the brake set-up I got. Luckily, they sent that part attached to the threaded rod, so I used it. Just one more "'68 ain't a '71" surprise.
Same with the carb linkage. I have to use the '68 on the cab and make a rod to attach to the Edelbrock 600 cfm. I'm going to use a '68 rod that LMC says is for a six cyl.
Stuffed one of my three steering columns thru the hole in the firewall and came home. Tomorrow's another day.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-26-2010, 11:20 PM   #1022
Hart_Rod
Hart_Rod's Avatar
Finished installing my new disc brake system on the 68 S/C truck, 13" fronts, 12' rears, all new lines and a CPP aluminum mastercylinder with built in proportioning valve. I also, installed a B&M line lock for good measure, .
Hart_Rod is offline
Old 10-27-2010, 04:42 PM   #1023
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I got these in the mail froma good friend today for the blazer now just have to find time to install them..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 10-27-2010, 06:29 PM   #1024
AirSpeed
AirSpeed's Avatar
I installed a new rear view mirror in my passenger door, the door never had one so I had to measure the drivers mirror about twenty times before I was happy enough to drill holes in my new paint! The new mirror is beautiful compared to the old one on the drivers side, now I have to replace that one! While I had the door panel off I installed a bunch of 1/2" thick rubber sheeting on the inside of the doors, what a big difference in the way the door sounds now! Sounds very solid when you close the door and driving is a lot quieter!
AirSpeed is offline
Old 10-27-2010, 07:01 PM   #1025
Sonicman
Sonicman's Avatar
Installed a new master cylinder and power booster and discarded my 41 year old master cylinder. I am excited I don't have to use all the muscle in my legs to stop my truck like Fred Flitsone did.
Sonicman is offline
Closed Thread
