Old 10-24-2010, 01:00 PM   #1
mfl1
mfl1's Avatar
van ralleys
curious if anybody has used the 6.5. my problem is i have 3" belltech spindles and 3" drop springs and now my control arm sits on my inner lip of the wheel. dont really want to cut on the arm if i dont have to. Thanks
mfl1 is offline   Reply With Quote
Old 10-24-2010, 01:31 PM   #2
bharrison1
bharrison1's Avatar
Re: van ralleys
i have them on my truck with 2.5 spindles and one coil cut i had to shave the control arm a bit
bharrison1 is offline   Reply With Quote
Old 10-24-2010, 01:37 PM   #3
mfl1
mfl1's Avatar
Re: van ralleys
do u happen to have any pics and was it the whole bend off the bottom. i bought 1" spacers but it moved the wheel out way to far now it kinda looks weird. o yeah thats with the stock ralleys
Old 10-24-2010, 01:48 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: van ralleys
I used some 15x6.5's on my trailer, does that help?
I think Joe put some on the front of his crew to help with clearance issues. Not totally sure of his drop, but you can probably find out in his build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=383701
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-24-2010, 01:56 PM   #5
bharrison1
bharrison1's Avatar
Re: van ralleys
not my pic but i found it on here this is what i trimmed off mine
Old 10-24-2010, 02:13 PM   #6
mfl1
mfl1's Avatar
Re: van ralleys
thanks 4 the pic
Old 10-24-2010, 03:29 PM   #7
jasonroman
jasonroman's Avatar
Re: van ralleys
im planning on getting 2.5 spindles soon. how did you cut that area off?
this something i can do on the truck? thanks
jasonroman is offline   Reply With Quote
Old 10-24-2010, 10:22 PM   #8
SCOTI
SCOTI's Avatar
Re: van ralleys
Trim the edge of the a-arm lip off using a cut-off wheel on an angle grinder. I drill a hole where I want the trimmed portion to 'end' & cut to the hole. I then use a grinding disc to smooth all the edges completely. No sharp edges = less opportunity for stress cracks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-24-2010, 10:40 PM   #9
joe231
joe231's Avatar
Re: van ralleys
I have 3" spindles and 6.5" van rallies.
my arms are trimmed like the pic above
CHEVY ONLY
joe231 is offline   Reply With Quote
