Serpentine belt conversion question?
picked up a 1979 SB 350. I wanna go with a serpentine belt set up, but can't afford aftermarker bling and chrome with the associated $$$ cost.
I have heard that late model GM serpentine set upd (Blazer, s-10, caprice, etc) will work on the 350 block. If so, I can get all that at the junkyard for about $100 or less, some powder coat "chrome", and I should be fine. Will this work, or is the swap not that painless? Thanks in advance for any help
During first and only engine rebuild " That O-ring? It's a spare I think, but lets keep it just in case we discover we need it" 1955 Chevy 2nd series, "Mabel" |
Arrived on a Pale Horse
Re: Serpentine belt conversion question?
should work fine, provided the heads have the bolt holes in the right spots, which they should.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
Happy to be here
![]() Join Date: Mar 2000
There was a thread recently on the subject that had links to older posts as well. Unfortunately I can't find it right now. Do some digging and you should get all you need to know and more...
Thanks, though I remebered reading it, this makes the engine a lot cheaper to rebuild now
![]() Join Date: Jul 2010
don't for get to get tha reverse flow water pump to go along with tha set up
Happy to be here
Chris
if you run a mech. fan the fan has to match the reverse flow.
I think it looks alot cleaner without sepr. setups, all them big brackets and pulleys. But it gets the job done.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
Windy Corner of a Dirty Street
This serpentine question comes up all too often.
Here is another helpful link. http://67-72chevytrucks.com/vboard/s...d.php?t=233335 You can also find info>>>>> The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ > FAQ Truck Tech > Engine and Drivetrain and pick Serp Setups from the list.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
| Bookmarks |
