Old 10-23-2010, 10:51 PM   #1851
menace121978
menace121978's Avatar
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
yes... quit a bit. its basically an entire harness. i have a diagram of Bob's i'll see if i can find and repost it up here for you.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-26-2010, 12:04 AM   #1852
yaya7881
glock what wires do i need on the truck to hook up my cruise control?
yaya7881 is offline   Reply With Quote
Old 10-26-2010, 12:32 AM   #1853
qu1cks1lver56
qu1cks1lver56's Avatar
that be awesome, thanks.
qu1cks1lver56 is offline   Reply With Quote
Old 10-26-2010, 07:19 AM   #1854
menace121978
hope this works... In case it is hard to see, the lettering on the 6-pin plug that goes into the switching valve is, from left to right on the diagram, F E D C B A. F is not used.
This drawing uses a generic on/off/on type switch. But for the factory switch, the wiring is:
A - Black (Ground)
B - Gray (Right Pump 12v)
C - Tan/Black (12V in to switch, to power pumps)
D - Tan (Left Pump 12v)
"Dennis the Menace"
Old 10-26-2010, 11:18 PM   #1855
softballnrd27
Always a work in progress
softballnrd27's Avatar
Holy crap my brain is in overload mode and I have made list after list of what I need to get in order to get my 6.0L swap going. Great thread and awesome truck!!!!
Any news on the swap book?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 11-10-2010, 01:57 AM   #1856
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Hi Bob;
I know this was an old post, but do you remember if the primer you used was a special engine / high temp primer, or if it was just regular metal primer?? I'm asking because I want to paint my engine but I can't find any high temp primer in the stores and I don't know if it is necessary or not ---- although I would think that it would be important to use if it was available.
Thanks!!
Gordon
Originally Posted by glock35ipsc View Post
Thanks! They are not headers, but the stock exhaust manifolds with the heat shields taken off. I am going to have them Jet-Hot coated. The red and aluminum paints are Rustoleum Engine Enamel.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 11-13-2010, 07:13 PM   #1857
fpjr0
fpjr0's Avatar
whats up guys? havent been around for a little while, wondering how your are doing with your swap kits bob?
man I want to do my air suspension if only I would sell my boat lol
ONCE YOU GO LS, YOU NEVER WANT LESS!!
fpjr0 is offline   Reply With Quote
Old 12-06-2010, 07:39 PM   #1858
djw32
I think I will pull the bed off this weekend just to get everything else cleaned up. I need to anyhow just to put the vents on the gas tanks.
That is the same hole I used for the temp sender. The original adapter I bought from S&P was a POS, so a fellow board member made me a couple that are the bomb:
With the POS adapter from S&P:
They work great! I had a small leak from the beginning, it seeped between the adapter and the sending unit, and it would drip onto the manifold. Not really a big problem, but man oh man burnt antifreeze stinks bad! So when I was finishing up the A/C I pulled the adapter out and used pipe dope between the sending unit and adapter, and between the adapter and the head. No leaks now!
Those adapters look great. Where can I get one? Are the stock gauges electrical or mechanical?
djw32 is offline   Reply With Quote
Old 12-07-2010, 12:27 AM   #1859
mcbassin
Still Learning
mcbassin's Avatar
Hi DJW32,
I actually made these adapters for Bob/Fred. I had some fall off scrap pieces that I made these for a few board members. I could make more if I had the material. C360 or C-3600 free machining brass hex stock.
Also, he used the oem style gauges electronic from an 88 up burb I believe.
Old 12-07-2010, 10:49 PM   #1860
jkade
jkade's Avatar
Glock, do you remember where the speed signal goes? The speedo has 3 inputs if I remember correct. I am putting a LQ9 in a military blazer and I am going to use the 91 cluster I have but I am unsure which pin to put the wire from the computer to. Is that all I need to do once I figure it out for the speedo to work? I know I have to repin my plug to match the 91 and I am switchind to a 91 tcase with the vss.
You will need the cluster from a 90-91 Suburban, Blazer or dually. Those used an electric speedo. The PCM from the LS will have one wire that will go to the new speedo, and the hookup is simple. I had swapped out with a Blazer cluster when I did the swap, but the trip odometer didn't work. I had picked up another speedo with a working trip odometer and it showed fewer miles, but had been putting it off and finally did it today.
So.. I got the "new" speedo installed, and it works, trip odometer too. Also got the other steering wheel on, and I like it MUUUUCH better.
I had to get up in the attic of the shop, and found the new deep trim rings that I originally bought for my 68. So I pulled the OEM shallow ones off and put the new deep ones on. It looks real good, and adds some more shine to it.
jkade is offline   Reply With Quote
Old 12-07-2010, 11:06 PM   #1861
jkade
jkade's Avatar
Thanks man, I appreciate it! It's been pretty straight forward so far, I really thought I would have a lot of questions and have things stump me since this is the first time I've ever done something like this. But all the planning has truly paid off! I really do think just about anyone could do this. There is a LOT to be done, but it's not nearly as daunting of a task as I originally thought it would be.
The speedo, and entire gauge cluster, is sourced from a 90-91 Blazer, Suburban or dually. The one I got is out of a Blazer. The electric speedo only needs one output wire fed to it from the PCM. When I got the cluster, I followed every circuit from the pin to see where it went, and made a drawing of the connector on the cluster and noted each pin and where it went. Today when I pulled the original cluster, I did the same thing noting wire color, what is was for, and what pin # it was in. Then I made another drawing of pin numbers, and where I needed to put each wire for the new cluster. The original cluster had 3 ground wires running to it, the new one only needed one, so I cut the other 2 off. That gave me a wire/pigtail I could use to run the speedo output wire to and put it in the right hole on the connector.
How did you figure what was a ground and what was hot on the 91 cluster? That is what has me worried as I don't want to smoke the 91 cluster. You still got the drawing?
EDIT: I found this thread with a excel ss with the pinouts... he left off which one was for the speedo though.
http://www.ls1truck.com/forums/lsx-t...ge-wiring.html
Thanks!!!!
Old 01-04-2011, 11:54 PM   #1862
SCOTI
SCOTI's Avatar
Good reading here.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-05-2011, 12:32 AM   #1863
mcbassin
Still Learning
mcbassin's Avatar
Where you at Bob? You need to pop in every once in a while to let us know you're all right.
Old 01-05-2011, 02:14 AM   #1864
p_rubottom
p_rubottom's Avatar
Originally Posted by mcbassin View Post
Hi DJW32,
Any chance you would be getting some more stock around?
p_rubottom is offline   Reply With Quote
Old 01-05-2011, 09:12 AM   #1865
mcbassin
Still Learning
mcbassin's Avatar
Occasionally some is on epay. I haven't checked in a while. To answer your question, maybe, not sure. We haven't had to make any parts that leaves the fall off behind.
Old 01-05-2011, 12:48 PM   #1866
68 TT
Still plays with trucks
68 TT's Avatar
It doesn't need to be some hard to come by material to work. We used plain old brass for machining many different fittings & bushings and it works well. Much stronger than the same part made out of aluminum would be.
Onlinemetals will sell you just a couple inches of material if that is all you need. They will custom cut it to any size you want and the price gets cheaper the more you buy.
1" brass hex rod:
http://www.onlinemetals.com/merchant...=81&top_cat=79
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-05-2011, 06:06 PM   #1867
erikgto
Hi guys,
I love this tread!!!
It's got me all wired up about doing the same with a small twist; maximum mileage!
My '86 swb has a 400sbc/700r4/2.74 combo right now.
With gas prices here in Europe around $ 8,- per gallon I want a combo I can drive as fuel efficient as possible. (I Loved the power and mileage on my old '98 LS1 Z28)
I don't push my cars hard, so I'm still thinking either a 4.8 or 5.3/4L60e combo.
I guess I'll go the Fred route,altough maybe a lower rearend? Like 3.08 or 3.23 or so with max. mileage in mind.
What's Fred's average mileage since the LS build? I only read about the mileage during the build.
If there was a place I could get all the parts needed for the swap at once.... That would be it for me since there are no 5.3 pullout combo's for sale here in Europe. Oridering every part bit for bit would really kill the deal for me....
1972 GMC 2500 Sierra 350
1971 Pontiac LeMans Sport 400 GTO/Judge Clone
1970 Pontiac GTO 400 convertible restoproject
1970 Pontiac Bonneville 455 convertible
erikgto is offline   Reply With Quote
Old 01-08-2011, 11:34 AM   #1868
monte0185
monte0185's Avatar
Man this is a long thread. Took me a whole day of work to read this. I love my job!!! I like a few others on here have Fred's Twin and have planned pretty much the same thing only Im going with a whole different suspension setup. I talked to nate and hes in the process of setting up a coil over front end and I think im going to go with a 4-link rear but after seing that ladder bar setup that could be interesting too. I figure a 5.3 should be plenty as my 05 suburban had one and it pulled my 16ft trailer cross country several times no issues. Lighter truck ought to be better. I appreciate all the great info this thread gives and cant wait to see what you have planned next. Here is a pic of my truck.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 02-11-2011, 09:51 AM   #1869
ronnieb
Glock are you out there?
This is a wonderfull thread, I have read and re-read several times and catch something new each time.
I have an '84 LWB completely restored but still has the 305/700R4 combo in it. I have finally assembled all the parts and a 5.3/4L60E to start this project. I do still need to send the harnes and computer in for mod to standalone.
I have one question right now with probably alot more to follow in the future. You made an extension to frame mount on the pass side to support the new motor mount location and mentioned you would make a template. I will be doing the samething to mine but can't find the template, but I'm guessing from the pictures that you added about 2-3 inchs to the mount?
ronnieb is offline   Reply With Quote
Old 02-11-2011, 09:58 AM   #1870
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Dern Bob, you havent been on here since October 10th. I hope you are just busy with work and family. Hope all is well with you brother! Hope to talk to you soon!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 04-17-2011, 12:29 PM   #1871
Hart_Rod
Hart_Rod's Avatar
Bump
Hart_Rod is offline   Reply With Quote
Old 06-16-2011, 12:43 AM   #1872
SCOTI
SCOTI's Avatar
Bumped again...
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-28-2011, 12:31 PM   #1873
truckzilla
truckzilla's Avatar
And yet, once more.
Bump.
truckzilla is offline   Reply With Quote
Old 06-28-2011, 12:47 PM   #1874
mcbassin
Still Learning
mcbassin's Avatar
It seems as though he has completely abandoned this thread?
Old 06-28-2011, 07:22 PM   #1875
ccreddell
ccreddell's Avatar
He hasnt posted anywhere on here in the last three months.
ccreddell is offline   Reply With Quote
