BMW & ASE Master Certified
Re: Does Bezel screw directly into Cluster?
Good to know, its something I will ask the rep when I get my last drawing done. The parts will be solid with no webbing. The gauge has 2 holes where you could insert tiny screws to the clusters trim plate in the rendering, that piece will be glued and bolted to the black trim and clear lense of the cluster. the back part will mainly be to take up the same space as the original cluster mateiral + position the lamp in the right spot. I need to ask what temperature ranges the material deforms at because its a bulb and bulbs get warm and it would be a waste if the bulbs melt the nylon.... I will check and post my findings.
heres what the cluster will look like when finished ![]() clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
