Closed Thread
Old 10-27-2010, 07:02 PM   #1026
dmwphoto
dmwphoto's Avatar
Re: What did you do to your truck today!
Originally Posted by AirSpeed View Post
I installed a new rear view mirror in my passenger door, the door never had one so I had to measure the drivers mirror about twenty times before I was happy enough to drill holes in my new paint! The new mirror is beautiful compared to the old one on the drivers side, now I have to replace that one! While I had the door panel off I installed a bunch of 1/2" thick rubber sheeting on the inside of the doors, what a big difference in the way the door sounds now! Sounds very solid when you close the door and driving is a lot quieter!
Little touches like that can make a big difference
Good job
dmwphoto is offline
Old 10-27-2010, 07:07 PM   #1027
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Will the mock-up ever end?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-27-2010, 07:47 PM   #1028
swamp rat
swamp rat's Avatar
Welded a 5" long crack on the rear of my frame right where the bumper mounts, not too sure how it got there,the bumper i took off was welded to the frame so ether it was welded because the frame was cracked somehow? or it cracked from being welded? the crack was almost directly in the center of and parallel to the welds.
Also made and mounted a ground strap for my fuel cell and ran the sending unit wire up to the cab but did not terminate the cab end yet.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline
Old 10-27-2010, 09:14 PM   #1029
sams60gmc
sams60gmc's Avatar
Originally Posted by FRENCHBLUE72 View Post
I got these in the mail froma good friend today for the blazer now just have to find time to install them..
Oooo nice.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 10-30-2010, 07:21 PM   #1030
Relish
Relish's Avatar
me and my brother put headers on my truck and then drove it home 30-45 minutes with open exhaust. on wednesday i'll be getting the exhaust done.
Relish is offline
Old 10-30-2010, 07:27 PM   #1031
dmwphoto
dmwphoto's Avatar
that had to be both fun and nerve wracking. WTG
dmwphoto is offline
Old 10-30-2010, 07:39 PM   #1032
Relish
Relish's Avatar
it was a blast but most deffinately nerve wracking and i eas really nervous cause i saw two cops. a stock 307 open header sounds awesome the only problem was driving on the high way with a 3 on the tree she sure was loud then.
Relish is offline
Old 10-31-2010, 06:27 AM   #1033
mcmlxix
Collector of Projects
mcmlxix's Avatar
Got the new body mounts and ORD 1" lift blocks in place... took forever to get the bolts out without hacking to floor....
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 10-31-2010, 09:29 AM   #1034
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Powder coated my hooks just gotta get some bolts for em.. Also picked up some weatherstrip adhesive for the new seals.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 10-31-2010, 08:10 PM   #1035
flashed
Bought some more Ralley wheels for it .I am currently running 6" van ralleys ,but now also have a set each of 7" and 8" truck ralleys .Now I need to figure out what is wrong with the sand blaster I borrowed so I can get them all blasted and painted and decide which ones to keep. My wife thinks it strange that I have 4 sets of wheels for one truck .
flashed is offline
Old 11-01-2010, 12:30 AM   #1036
rakerkman
rakerkman's Avatar
Had a great time replacing the heater core in my 70 C-20. Found a bird nest stuck in there and while I was at it found got rid of some useless wiring that the previous owner had redone but never removed. I got heat now and a little less weight so she might go faster.
rakerkman is offline
Old 11-01-2010, 01:28 AM   #1037
lil hoodlum
lil hoodlum's Avatar
I had a productive day, I painted the inside of my tailgate, front bed panel, and the white on top of the doors. The paint is dupont light blue #507.
Tomorrow, I am supposed to get some parts that I order earlier in the week. New headlight bezels and attaching hardware, new door handles, and new rear cab molding.
With in the next month I plan have on having the interior painted, seat recovered, new dash pad, and new carpeting. I am excited!
Keith
lil hoodlum is offline
Old 11-01-2010, 07:16 AM   #1038
rsavage
rsavage's Avatar
Pulled the 307 from the Burb. Now I'll clean up the engine bay and install the 350. Received the Goodmark rockers Friday for the Blazer. Thia week heading to Mich. to bring home a parts Blazer.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline
Old 11-01-2010, 11:47 AM   #1039
swamp rat
swamp rat's Avatar
Originally Posted by bossermj View Post
Anyways, we get a lot of rain in WA this time of year so looking for temporary carport. Single car garage is full at the moment with a Model A.
Check with Pep Boys if your looking for the inexpensive aluminum tube frame and tarp variaty, they usually have the lowest price. Whatever you buy make sure its fastened down to the ground, fence and even your truck this winter as the wind will want to take it away, I use bike tie down straps and rope, and pep boys even carries ground screws that are nothing more than dog runner lead screws from a pet store but they work.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-01-2010, 11:53 AM   #1040
Cisco714
Finally finished tearing out all the original ducting for the A\C and heater. Taped/ pappered everything up and now ready to start sanding and primer, sometime this week. As soon as I get a chance I'll post up some pics.
Cisco714 is offline
Old 11-04-2010, 08:37 PM   #1041
lil hoodlum
I've had another productive day! I finally had some time to take the grill out and sand it down smooth and paint it white. I also installed new head light bezels and my new chevy bowtie.
Everything had been coming along smoothly which is definitely nice!
Keith
Old 11-04-2010, 08:43 PM   #1042
FRENCHBLUE72
PROJECT 7DEUCE
Got my radiator black from eastwood today so I can match my e fan shroud to the radiator..
MEMBER #6377
Project "7DEUCE"
Old 11-04-2010, 10:12 PM   #1043
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I went out and got this old radio for $10, and ya it works
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline
Old 11-06-2010, 05:45 PM   #1044
67Slider
67Slider's Avatar
Worked on the bed wood today. Cut it all down to size. I still need to notch the boards. But its looking like a truck bed again.
[IMG][/IMG]
Best part is both my sons worked on this with me.
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 11-06-2010, 05:50 PM   #1045
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
bed looks nice, I opened up all 8 boxes from CPP drooled a bit, turned the heater on in the shop, dropped off my lower ball joints to be pressed in and as soon as they are ready I pick them up and head into a hopefully somewhat warm shop and start painting all the new parts and final coat my frame in preparation for the rest of my parts needed to do the install of all my parts
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline
Old 11-06-2010, 05:57 PM   #1046
id_unavailable
put a new hei distributer in. The old rotor moved about a 1/4 inch. The rotor was hitting the contacts in the cap. How it ran is beyond me.
67 slider I like the bed. Most people avoid knots but for some reason I like the character.
id_unavailable is offline
Old 11-06-2010, 06:25 PM   #1047
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Hung the fenders(temporarily)after installing the headers, and painted the new floor pans and rockers. Then reistalled the seat. getting ready to freshen up the fuel and light that posi up!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline
Old 11-06-2010, 06:43 PM   #1048
Sillyoldman
#16876
Sillyoldman's Avatar
I walked by mine and ran my hand down the side as I went outside to work on the septic system.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline
Old 11-06-2010, 07:50 PM   #1049
67Slider
67Slider's Avatar
Almost 80 in Colorado today. Unheard of. Worked in the yard this morning and worked in the garage with the door wide open all day. Kids are still outisde playing without coats at 6PM.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 11-06-2010, 08:45 PM   #1050
60ratrod
yes, i do
60ratrod's Avatar
Damn, you guys are having a mild winter. My dad did say that it has been rather mild so far. Anyway i made a dump run in my 72. I need to get some sound insulation in that thing
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Closed Thread
