Old 10-27-2010, 09:55 PM   #1
Roadmarks
Roadmarks's Avatar
Question Transmission Cooler Bypass?
Howdy, I have added an external trans cooler and filter to the nose of my '71 C10. The outfit that I got It from, Makco Distributing, strongly suggests a "cooler bypass" for very cold starts. I don't mind adding it if it is really needed, but the original "in the radiator" cooler doesn't seem to need it. Are these guys just trying to stick their hands deeper in my wallet, or do I need to look into this further? My flow pattern will be through the filter then original rad cooler then through the add-on cooler. Comments or thoughts?
Roadmarks is offline   Reply With Quote
Old 10-27-2010, 10:04 PM   #2
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Re: Transmission Cooler Bypass?
IMO, the bypass (add-on cooler only) would be handy if you see temps below 40 or so.
There's no bypass for the radiator cooler because that one doubles as a trans fluid warmer during cold weather running.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 10-27-2010, 10:22 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i would route it through the original cooler (rad) last. No need for a bypass at all
Old 10-28-2010, 06:03 AM   #4
raycow
Longhorn has it right. Radiator cooler last. This also has the advantage of putting LESS heat into your cooling system when you are running hard and hot.
Ray
raycow is offline   Reply With Quote
Old 10-28-2010, 09:10 AM   #5
cdowns
cdowns's Avatar
when i lived up north in newyork i never had a cooler bypass the tranny worked fine even in below zero temps
Old 10-28-2010, 10:47 AM   #6
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Exclamation Re: Transmission Cooler Bypass?
Ray
These guys have all given some very sound advise.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 10-28-2010, 12:12 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This is how one transmission website shows it . It looks like the fluid routes to the radiator and then to the air cooler. I don't think it makes much difference but the trans fluid will transfer heat faster to the radiator fluid than it will to the air around the cooler.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-28-2010, 12:42 PM   #8
mrein3
mrein3's Avatar
I doubt the coldest start in North Carolina is any where near where I've run my truck. I have an external cooler and no bypass.
I do know a guy that has an "H" plumbed into his system. He completely bypasses the coolers (radiator and external) on really cold days.
Plumbing wise you want the external cooler before or after the tank in the radiator depending on where you live.
Up north here you run the hot tranny fluid to the external cooler then to the tank in the radiator. This keeps the fluid a touch warmer. You can get it too cold.
Guys in hot climates will want to run it to the radiator then to the external cooler for maximum cooling effect.
Back to the bypass question. If you go without one, just wait until the truck warms up a tad before you take off if you're worried about it.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-28-2010, 01:46 PM   #9
Roadmarks
Roadmarks's Avatar
@VetteVet, Thanks! I have that diagram and instructions that came with the cooler, and that is the way I plumbed it. I was just curious about the by-pass. At this point, I'll save the $35 and wait and see.
@mrein3, You got that right! We have a LOT more days over 90 than under freezing! Thanks!
@everyone else, Thanks for the input!
Old 10-28-2010, 02:25 PM   #10
turp mcspray
turp mcspray's Avatar
I just put a piece of cardboard in front of my trans cooler in the winter.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
