Anyone else find these a pain in the a$$ to snap in?
![]() I am trying to get the inner grill snapped onto the outer, but these things do not want to go in. Any trick that I am missing, I know it shouldn't be this difficult, and I do not want to bend my grill in doing so. I bought some spare clips off classicparts.com, you would think they would fit. Kind of a stupid question. Thanks for the help. |
![]() Join Date: Apr 2010
Re: 71-72 grill clips
I had the same issue. Ended up using 1" carriage bolts on the lower and regular 1" bolts with lock washers on the top.
If the outer grill was not on the truck, likely easier to use the clips but was nearly impossible with outer already on truck. |
![]() Join Date: Aug 2009
Have to agree these are a real pain, mine is out and cannot get the clips in, so hopefully someone has an easy way to install
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
Active Member
Did you buy the exact kit from LMC? I put mine in and they went in fine.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car ![]() 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! |
i,ve got a kit from lmc and ones from local body shop supply and still will not fo into a NOS grille
Yeah, bought the kit from classicparts.com, and it is a nos grill.
yeah i also gave up and just went with bolts.
Might try to use a little lube of some type to aid in pushing through. They can be tough as crap to do. Something else to try is get them warmed up in some boiling water to soften them some before pushing them into the grill.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Cruzin
i just assembled my grill today got the clips from classic parts and the grill outer is a aftermarket and the grill is too took about five minutes. I did however snap the clips in thinking the inner grill attached to them
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
