A lot of tachs showing up on ebay
Usually might see one now and then but was browsing last night and came across five! Guess that also means there are another five square bodies no longer on the road.
Wish there were actual production numbers to know how many millions were produced. They still seem to be breeding somewhere with rust no longer an option! ![]() http://cgi.ebay.com/ebaymotors/73-87...item3a5fe12253 http://cgi.ebay.com/ebaymotors/1973-...item5195eac696 http://cgi.ebay.com/ebaymotors/80-87...item3a5fe11fa2 http://cgi.ebay.com/ebaymotors/73-74...item1e5f4a2f60 http://cgi.ebay.com/ebaymotors/73-87...item3a5fce515a Take your pick if so inclined. ![]() Enjoy the day, Mark ![]()
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." ![]() |
Re: A lot of tachs showing up on ebay
I have some I want to sell, but too many on there now....but no still no diesel tachs....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
I'd like one for the 85 C-30 but the install would have to be dummy proof. There is one there that supposedly came from an 85-86 suggesting plug & play for the cluster but lacks the wiring for the tach.
I get confused easily if the parts are not all there. I've learned to use my ears with the C-30. ![]() Mark ![]()
If you get one from a 78+up, it will be a plug and play. The wiring for the tach is easy, even if you don't have the original wiring. One to a keyed positive, one for ground, one for TACH on the distributor.
I swapped a tach cluster into a couple trucks I used to have, one being an 87 that was injected, worked great. Shouldn't have sold the truck with them still in there.
Getting Old; Going Broke
One of them is a 7k tach, never seen that before. It also has a 100mph speedo with a VSS hooked to it? Can't say I've seen that before either. Granted I'm not very well versed in the 80 and down stuff.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
That one is something that was built. The speedo is a regular 70s style, and the tach is out of a Camaro, dunno what year. VSS was just added on the back of the speedo.
#7 | |
![]() Quote:
Is that fairly easy to do on an older speedo? I plan to use a '77 cluster (complete with vacuum gauge and tach) in my K30 build, but would love to use the newer cruise system. Back of the 100 MPH speedometer is embossed for the sensor head...is it as easy as cutting the metal out, or is there more to it? Any info appreciated, thanks Joe Posted via Mobile Device |
I think you just need to thread it in. It's soft metal, so shouldn't be too hard....
#9 | |
Thanks for the reply. Mine isn't actually cut out for it though ![]() Thanks for the help, Joe P.S. - Weren't you the one I spoke with on Pirate a while back about a vacuum gauge? ![]() Posted via Mobile Device |
