10-22-2010, 12:29 PM | #1 |
Power Steering
I am in major need for power steering. i dont like the fact that it gets away from me in a corner when i step on it with manual steering. what is the newest year of truck that i could steal the power steering off and have it bolt up to my truck with NO fabrication? or just the cheapest way to get power steering for it.
"Its better to burn out than it is to rust!" '70 GMC C10 2wd. 2.02 aluminum heads. TH400 trans. 450WHP '04 Nissan 350z DD, Twin Turbo, 600whp, drag beast! |
11-01-2010, 12:28 AM | #2 |
Re: Power Steering
Wish you guys could answer. I am in need of the same info. Please throw some knowledge our way. Thanks in advance!
11-01-2010, 01:17 AM | #3 |
Re: Power Steering
subscribed...need it in my 70
11-01-2010, 04:30 AM | #4 |
Re: Power Steering
The newest year is 67 or 68. This is the external cylinder style and it is a total bolt-on. It all goes on the linkage. You don't have to do anything to the gearbox.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-01-2010, 11:23 AM | #5 |
Has more rust than truck...
Re: Power Steering
11-01-2010, 12:58 PM | #6 | |
Re: Power Steering
Smoke em if you got em! Last edited by Fitz; 11-01-2010 at 01:13 PM. Reason: typos |
11-01-2010, 01:05 PM | #7 |
Re: Power Steering
You can use the power steering box from a 1973-87 Chevy or GCM truck and it will bolt right in. I used a 79 Chevy truck complete front suspension with the steerign box in my 67 extended cab truck.
11-01-2010, 02:10 PM | #8 |
Re: Power Steering
Note that the link posted above is not for a "no fabrication" conversion. It involves replacing the steering gear, which requires modifying the frame or using an aftermarket adaptor plate, and shortening the intermediate shaft.
The only true bolt-in swap is the external cylinder type, which would have been the system offered on 67 (or 68) and earlier trucks at least back to 63. 60-62 may also work, but I can't be sure without seeing one first. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-01-2010 at 02:13 PM. |
11-01-2010, 02:57 PM | #9 | |
Re: Power Steering
11-01-2010, 03:07 PM | #10 |
Re: Power Steering
I once converted a 69 GMC to power steering. The gear from a 76 bolted right on. For the 67-72 trucks, 1967 is the only model that does not have frame clearance for the box conversion. More recently, I put a 79 box on a 72. No problem.
11-01-2010, 03:20 PM | #11 |
Re: Power Steering
Sorry, I should have looked at your sig. Yes, a 70 will have the frame dimple needed to clear an integral PS box.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-01-2010 at 03:33 PM. |
11-01-2010, 03:46 PM | #12 |
Re: Power Steering
A 67 does as well!
11-01-2010, 03:51 PM | #13 |
Re: Power Steering
11-01-2010, 04:08 PM | #14 |
Re: Power Steering
Thanks!
Mercedes Medium Silver, Honda Bright Silver and Spies-Hecker Cherry Red shot over a black undercoat. |
