10-31-2010, 10:36 PM | #1 |
need help decoding my engines
need help decoding my engines i have two 327ci.
first one (nice one) back of block 3782870 F133 front pad that is stamped 318856 FO6I8RD HEADS 3917291 SECOND ENGINE (DIRTY 327) back of block 3782870 K221 front pad that is stamped FII24R
1969 chevelle 350 numbers matching 1971 chevy lifted 4x4 (the break up build) http://67-72chevytrucks.com/vboard/s...d.php?t=423605 1993 subaru impreza 1969 blazer cst 8" lift |
10-31-2010, 10:46 PM | #2 |
Member #1049
Re: need help decoding my engines
First one is:
block #3782870= 1962-1967 327 2 Bolt RD code = 1962 327 m/t, high perf. 300HP 4bbl Vette heads #3917291 = 302,327,350 67-68 "Camel Hump" head, 161/65cc port volumes Second one: R code = 1962 327 m/t - - full size |
10-31-2010, 10:56 PM | #3 |
THANK YOU! i was looking allover on line and getting so many different answers
10-31-2010, 11:17 PM | #4 |
That vette 327 is probably worth a lot to a vette collector. Great heads too....
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 Last edited by gkesseru; 10-31-2010 at 11:17 PM. |
11-01-2010, 12:12 AM | #5 |
I'm going to check my 327 when it comes back from shop.
Supposed to be 65 Vette but we will see. I have VIN# question; can you decode this -- CS138Axxxxxx? Thanks |
11-01-2010, 04:18 AM | #6 |
that vette engine goes into my truck untill i get money for a 383 stroker for my chevelle then my truck
11-01-2010, 05:24 AM | #7 |
Your first engine has a casting date of June 13, 1963, so is likely 1963 model year. The second one is Nov 22, 1961, so is definitely 1962.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-01-2010, 06:58 PM | #8 |
JJ your truck was a factory six cylinder as per the CS prefix built in atlanta, it is a half ton, i assume it is a stepside and is a 1968 model
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-01-2010, 07:13 PM | #9 |
so is my vette 327 62 or 63?
11-01-2010, 07:33 PM | #10 |
>>>First one is:
block #3782870= 1962-1967 327 2 Bolt RD code = 1962 327 m/t, high perf. 300HP 4bbl Vette heads #3917291 = 302,327,350 67-68 "Camel Hump" head, 161/65cc port volumes <<< Livrat can you explane what RD code is please, Thanks!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-01-2010, 07:52 PM | #11 | |
I've been checking it. I found lists but they didn't show what the '3' meant, even my original service manual says it should have a 6 digit number between the CS & the A. The VIN in the glove box and the pillar match. There is also a model # on the option list but can't quite make out the 1st #. It could be a '1' based on the small line I can see, but could be a '2' also, since that # refers to GVW and I have HD rear spring option. I've attached a photo. It is a 68 shortbed stepside 1/2 ton. If I decode it correctly, the 3 means cab & chassis with no bed, whereas if it was a 4 it would be cab and bed. Not sure if that's right or not. Last edited by JJchamp48; 11-01-2010 at 08:03 PM. Reason: forgot picture |
11-01-2010, 09:25 PM | #12 |
Member #1049
(FO6I8RD) "RD" are the last two letters stamped on the front of isaacf's 327 block, they are stamped as to what car that particular engine was installed into.
11-01-2010, 10:22 PM | #13 |
Thanks! and nice meeting you at the swap meet too!
