Old 10-31-2010, 09:01 PM   #1
LandonL
LandonL's Avatar
Would running straight water be causing a slightly higher temp?
I've been running just water in the cooling system just for the motor break-in just to make sure I had no leaks so I wouldn't lose my expensive (to me lol) antifreeze. I was, and AM going to put the antifreeze in it of course but just had this question.
I'm not sure if it's because it's a freshly rebuilt motor, or because I'm running straight up water but the block and parts like intake/valve cover feel hotter than they did before the rebuild.
I'm using a good 180 degree thermostat, the temperature gauge never reads anymore than it did before the rebuild but I'm just running water at the present time, would this cause the block/parts mentioned to feel a tad hotter than normal?
Once again, I'm putting the antifreeze in it, just wanted to know if it was something else that may be causing the abnormal block heat. Other than me being crazy of course and just thinking it's hotter.
Thanks as always!
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 10-31-2010, 09:10 PM   #2
82swampthing
82swampthing's Avatar
Re: Would running straight water be causing a slightly higher temp?
a fresh motor is going to be warmer any way because of the friction of the new motor breaking in,but yeah i would get antifreeze in there it helps with cooling and it also lubricates the water pump.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 10-31-2010, 09:49 PM   #3
LandonL
LandonL's Avatar
How long does it usually take for everything to break in, as this is my first ever rebuild I have nothing to compare too.
250 L6 .030 over
Old 10-31-2010, 09:52 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
depending on tolerances, a motor can take anywhere from 500 to 1000 to "break-in". be careful with it, vary the rpms, no full throttle romps, change oil @ 500, no long periods of time @ idle.
piece of cake.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-31-2010, 09:54 PM   #5
huero
1969 Short, Fleet, and Beat
huero's Avatar
water cools better than antifreeze.
huero is offline   Reply With Quote
Old 11-01-2010, 12:09 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
50% antifreeze mix boils at a higher temp than water, but I didn't think it cools any better. I agree that your somewhat higher temps are simply from having a new engine.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-01-2010, 02:14 AM   #7
huero
huero's Avatar
water transfers heat better that antifreeze.
Old 11-01-2010, 02:43 AM   #8
gearys 5600
gearys 5600's Avatar
Break in ?? Whats that ? lol
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-01-2010, 05:53 AM   #9
cdowns
cdowns's Avatar
it rusts better with water
Old 11-01-2010, 06:04 AM   #10
Shaky
Six in a row makes it go...
Shaky's Avatar
This. Water has a higher specific heat than mix.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 11-01-2010, 10:52 AM   #11
tqlspec
tqlspec's Avatar
Antifreeze has anti-corrosion agents in it. You need it.
Retired Navy
1972 C10 Cheyenne fleetside
350 sbc, 700r4, 3.42 rear
tqlspec is offline   Reply With Quote
Old 11-01-2010, 11:23 AM   #12
Alex Hayley
Is you cooling water slightly rust-coloured? Mine is because I used too little coolant. Now I have rust-coloured antifreeze mix. Use an antifreeze mix even if it is not too strong of a mix. Any way to get rid of a the rust colour? It is difficult to drain ALL of the coolant.
Alex Hayley is offline   Reply With Quote
Old 11-01-2010, 02:28 PM   #13
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Water also freezes....Water also changes states when it boils...
Alex,
If its that bad, you may have to do some serious flushing along with some parts replacement to get all the rust out.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 11-01-2010, 03:43 PM   #14
LandonL
LandonL's Avatar
Guys I planned on running the 50/50 mix from day one, I was just doing water for the time being so I didn't waste antifreeze if I had any leaks. Thanks for everyones responses.
250 L6 .030 over
Old 11-01-2010, 06:57 PM   #15
ERASER5
ERASER5's Avatar
I have done the same thing. Just to check everything out, then replace with 50/50. Water will cool a bit better, but not WORK better. JUST DON'T FORGET!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-01-2010, 10:27 PM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
In theory, water will cool better. However, in my observations, an engine with coolant will run a tick or two cooler.
If you are just going by "the valve covers seem hotter" then you can't tell. No one has a hand calibrated that closely.
Old 11-01-2010, 10:50 PM   #17
a.c.1
Most antifreeze is also called antiboil. Its designed to raise the boiling point of water along with the pressure in the system created by agood radiator cap. I've also heard of overbored cylinders causing this... not sure though.
a.c.1 is offline   Reply With Quote
Old 11-01-2010, 11:34 PM   #18
huero
huero's Avatar
From what I understand nothing cools better than water. Water will not boil at 212 degrees being it is under pressure. Straight water dissipates heat best, better than antifreeze mix. But antifreeze has the anti corrosion prohibitors your system needs, as well as, you guessed it anti freeze properties (as you already knew).
Your engine is running hotter because it is new (as mentioned before). Water for break in should not be an issue.
I would not run it with tap water but, I would use distilled water and I would not go more than a couple of days before I would drain that an add the antifreeze.
When you say break in I would think you mean running it for 20-30 minutes to break in the cam.
Being in sunny so cal I like 70% distilled water and 30% antifreeze.
Good luck, huero.
