bed bolts
i took my bed apart and broke all the bolts off and was wondering is there a place to look at for sizes of bolts i need and what not..kinda a dumb question
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Re: bed bolts
Re: bed bolts
If you have a local Ace Hardware Store I would give it a try....anytime I need some kind of bolt or nut for my truck they had them.
Re: bed bolts
thats what i was plannin on doing. lmc bolt kit is kinda pricey so i figured a bolt is a bolt and you can get them cheaper at a hardware store instead of paying like $2 a bolt at lmc i found you can get a bolt for like less then a doller at the hardware store
Re: bed bolts
count up your bolts..
the kit is 29 bucks.. at a buck a bolt at hardware store( don't forget the washers and nut is extra) you have only 29 bolts.. I'll bet the kit is cheaper than the local hardware store.. the S/S is 59.00 have u priced bolts/washers/lock washers(if used)and nuts non graded junk you might get at 1.29 a set (bolt/washer(s)/nuts) MIGHT.. good luck.. |
Re: bed bolts
local purchase no wait no shipping costs which people dont include in there "bargin" prices they quote from LMC
no need for "graded" bolts as there is no load to speak of in an assembled bed for better grade tho look at a boat supply place my local fastener company has galzanized for less than50cents each stainless less than a dollar
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 11-02-2010 at 08:31 AM. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: bed bolts
Try your local Tractor Supply Company or Fastenal store, probably be cheaper than most hardware stores.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 11-02-2010 at 12:14 PM. |
Re: bed bolts
The large washers with the offset square hole is not available in hardware stores. These are the ones that hold the bed down.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
