Old 11-01-2010, 03:13 PM   #1
jcloud6
How do I stop 700R Transmission from leaking at tail end
I have replaced the rear bearing and seals in my 700R Transmission, by the next weekend its again. could it be the wrong drive shaft yoke because there is a little play after installing new tail shaft bearing?
jcloud6 is offline   Reply With Quote
Old 11-01-2010, 03:59 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: How do I stop 700R Transmission from leaking at tail end
Mines the same way, drives me nuts having a leak like that. I'm at the point where I'm just going to wait and have it rebuilt once it starts slipping a bit more.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 11-01-2010, 04:48 PM   #3
Jonboy
Slots go on anything!
Pull the driveshaft out, and put a small piece of cardboard in the end of the yoke, small enough that it will stay in the end of the yoke. The tailshaft is leaking out of the hole in the output shaft. The cardboard will help stop the leak.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 11-01-2010, 09:16 PM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
just wondering.... but is it over filled? is that why it leaks out of the output shaft? Whats the purpose of having a hole in the yoke?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 11-02-2010, 10:23 AM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Could this be your problem?
http://73-87.com/7387garage/drivetrain/yokeleak.htm
I had the same problem with my TH350C. I fixed it tempoaraily by cleaning the hole with brake cleaner, then using the tip of a screwdriver to dab some RTV on it. Later on, I bought the correct o-rings for it, and the problem, went away.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-02-2010, 02:18 PM   #6
PRattenbury
Weld the hole in the yoke shut.
PRattenbury is offline   Reply With Quote
Old 11-02-2010, 02:51 PM   #7
82chevy350
82chevy350's Avatar
thats what i did on my t350 i just welded the hole shut
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 11-02-2010, 03:30 PM   #8
silvereagle07
silvereagle07's Avatar
You can put axle grease on the splines to slow it down. If you close the hole it will cause the suction in the yoke and not allow it to move freely. The hole is there to vent the air between the output shaft and yoke.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 11-02-2010, 07:45 PM   #9
Ceeten
Output shaft o-ring. Trans shop should have them laying around. About a 5 minute fix.
Ceeten is offline   Reply With Quote
Old 11-03-2010, 04:22 AM   #10
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: How do I stop 700R Transmission from leaking at tail end
x2
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 11-03-2010, 06:48 AM   #11
PRattenbury
Sometimes they just don't seal. And you need to weld it shut.
