Old 11-02-2010, 08:15 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
Whats a 68 or 69 Impala 427 motor worth
I just found a truck that has one in it, non running, just the motor no brackets or pullies. Block number 3963512. Thanks for any help, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 11-02-2010, 08:30 PM   #2
jocko
jocko's Avatar
Re: Whats a 68 or 69 Impala 427 motor worth
Here are the possibilities for this casting number (that I could find):
3963512 427 68-69 Passenger 385,425 HP
3963512 427 69 Chevelle, Camaro COPO (Central Office Production Order)
3963512 427 69 Corvette Late 69
3963512 454 70 Corvette, Passenger 360,390 HP
3963512 454 70 Chevelle LS-6 450 HP
3963512 454 70-71 Pass,Chevelle, Monte Carlo
3963512 454 71 Corvette 365,425 HP
So, if you're sure it's a 68/9 passenger car motor - then you know it's either a 385 or 425 hp eng. I'd say regardless of vintage - any 427 is worth a good bit of dough. The question really should be "why isn't it running"? Is it siezed? Does the seller say what's wrong with it? I'd sure want to know that it can rotate - at a minimum. If it can spin (even by hand with a wrench on the crank bolt) I'd say it's probably worth buying as long as there's no rods hanging out of the side of the block.... as for "how much" - not sure - I'd say a complete long block (that isn't running) may be worth up to $200-$400. If it's in really good shape with all the accessories still dangling (edit-sorry, re-read your post and see it has no brackets, so probably not worth much more), probably worth a little more. If you really need/want it, and can accept knowing it probably needs a rebuild, then it is up to you and your wallet - or if, perhaps, it's not a passenger car motor and is a vette motor(!) then it's probably worth more to a purist. Would need more numbers off the block than just the casting number. Good find! Good luck!
Old 11-02-2010, 08:56 PM   #3
68350
68350's Avatar
Any chance you can get the suffix code of the front of the motor? The COPO and LS-6 blocks would be worth the most out of the list posted above. If it's one of the others I would say 400-600 if it is in good shape with no damage.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 11-02-2010, 09:01 PM   #4
teeitup
teeitup's Avatar
Sorry I didn't get the code off front pad, I was going by what the owner said on impala. It was in a running truck till he wrecked it. Been sitting for a couple years. I can sell 402's and 396 for $300-$400 for bare motor, didn't know if 427 was worth more or not. Thanks Randy
1980 chevy swb 4x4
Old 11-02-2010, 09:04 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
If it's a COPO or LS6 engine, you are looking at some potentially serious money. I agree, the suffix code would shed a whole lot more light on the subject.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 11-02-2010, 09:41 PM   #6
68jewel
On the path to financial ruin!
68jewel's Avatar
Don't know much about codes and all. But, I do know original 427's are worth alot of money because there aren't many of them left today. Also, if you go to get it rebuilt, make sure you write down all numbers, etc. because many engine shops will try to keep the block since they are so rare. Trust me, that engine is worth more than $600 as is. Rebuild correctly and it is worth a couple of thousand.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 11-02-2010, 10:04 PM   #7
stich626
it it's a dated 427 grab it..
stich626 is offline   Reply With Quote
Old 11-02-2010, 10:11 PM   #8
teeitup
teeitup's Avatar
I'm not sure what I'd do with it, he asking $750 for it, I guess I could set it back and sell it later, it would probably make more than my investments are
1980 chevy swb 4x4
Old 11-02-2010, 11:18 PM   #9
JDL
JDL's Avatar
I look it over real good look for water in the oil or rust were the oil gres on the outer block melted off becouse it was run real hot. If all is good and usable get the date cods and it will bring over a grand shipping would be worth it.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 11-02-2010, 11:23 PM   #10
teeitup
teeitup's Avatar
I just talked to him he said it had these numbers on the pad T0319LE on it, Any help
1980 chevy swb 4x4
Old 11-02-2010, 11:25 PM   #11
cheyenne shortstep
cheyenne shortstep's Avatar
I am by no means an authority on this but I think the 512 blocks are desired by resto guys and I would do some research before selling it. If you were closer I might try to hoodwink you out of it.
cheyenne shortstep is offline   Reply With Quote
Old 11-02-2010, 11:37 PM   #12
JDL
JDL's Avatar
Code LE, Year 69, CID 427 , Vehicle Impala, HP335 , RPO LS-1, Trans TH-400 , Carb 4-Brl , Comments Super Sport
Not a camaro or Vet but still a good item
72 nova project car
Agency Iowa
Old 11-02-2010, 11:51 PM   #13
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: Whats a 68 or 69 Impala 427 motor worth
well there ya go... an original IMPALA 427... worth every penny IMHO...
QKENUF4U is offline   Reply With Quote
Old 11-03-2010, 12:52 AM   #14
68350
68350's Avatar
If the motor checked out(no damage), I'd buy it. Don't see 427s around too much, let alone a short deck for under a grand.
Old 11-03-2010, 12:58 AM   #15
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
You know Randy, dad has always wanted a 427 in a car for him. LOL
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-03-2010, 11:16 AM   #16
m6z
m6z's Avatar
Since It's an Impala motor $750 seems on the high side.
Good condition with a good steel crank - maybe
Good condition with a good steel crank and rectangle port heads - It would be a steal
I'm going to assume its has oval port heads since its a 365 hp motor.
The only reason the 427s bring good money is for restos. So you could always luck out and find some one restoring a 427 impala that has to have it. I'd rather stick to 454's. More displacement, cheaper and easier to find.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 11-03-2010, 12:54 PM   #17
teeitup
teeitup's Avatar
Thanks guys, I've got a message to him, waiting to hear back. I can find 454's all the time, I just don't see that many 427's very often, the ones I do see are out of big trucks and are tall decks. It was a running motor when he wrecked the truck, I talked to a buddy of mine who knows him pretty well said he remembered when he wrecked the truck, said motor was good. Thanks Randy
1980 chevy swb 4x4
Old 11-03-2010, 04:37 PM   #18
teeitup
teeitup's Avatar
Well I bought it, picking it up tomorrow evening. I'm not sure what I'll do with it but I'm sure it will be for sale and if it doesn't sell it can sit in the shop for a project when my son gets older. Thanks for all your help, Randy
1980 chevy swb 4x4
Old 11-03-2010, 05:09 PM   #19
68jewel
68jewel's Avatar
Trust me, you will not have a problem selling a 427. I don't care what it came out of. Regardless, if it's a Camaro, Impala, Corvette, etc engine, it will sell. I can guarantee it. Maybe not on here, but put it on Ebay or some other muscle car sites and it will fly out of your garage.
Old 11-03-2010, 08:02 PM   #20
QKENUF4U
QKENUF4U's Avatar
100% agreed.... i figured find some old IMPALA SS forums like this one and put it up on there..... should sell real easy for that guy looking for a correct engine for his restore..
Old 11-03-2010, 08:32 PM   #21
stich626
A 454 MIGHT HAVE MORE CUBES BUT A 427 IS A FAST TO REV .
and will get you moving faster..
Old 11-03-2010, 09:47 PM   #22
CG
BlahBlahBlah
You should PM Livrat. He is an expert on these engines.
Old 11-03-2010, 10:18 PM   #23
DA68
The Corvette guys will buy the 512 blocks all day long.
They deck the blocks and re stamp them with the Corvette suffixes.
I sold a bare block 15 years ago for $500 cash to Pro Team Corvettes in OH.
427 Impalas are pretty darn rare in their own right.
I don't see you losing money on this one.
DA68 is offline   Reply With Quote
Old 11-04-2010, 07:09 PM   #24
teeitup
teeitup's Avatar
well its here, have a guy coming to look at it Fri afternoon. Also got some extra parts afterall that will be for sale. Thanks to all of you for your help, Randy
1980 chevy swb 4x4
Old 11-04-2010, 07:09 PM   #25
teeitup
teeitup's Avatar
more
1980 chevy swb 4x4
