HELP !!! Sheet metal alignment
I'm new to the forum and need some good input on my project. I've replaced inner and outer rockers, partial floor pans and started doing assembly before I take it back apart for paint paint. My problem is the passenger side door. When I fit the the door the front edge of the door is 1/4" behind the rocker. The driver side is even with the front of the rocker. I've measured from the A-pillar back to the front of the rocker and it is the same on both sides. I can't move the door anymore foreward. The cab shows no evidence of a hard collision. Any ideas ? Is the front of the door supposed to be even with the rocker ? I should have taken pictures before teardown.
Re: HELP !!! Sheet metal alignment
How does it fit overall everywhere else. Is the gap consistent all around? Have you test fit the fender and checked that gap? It is not uncommon to have to build an edge with weld to get the gaps like you want them. Tolerance on fit was apparently very high, no ball bearing rolling around the door gaps from the factory for sure. Pics would be nice.
Slowly but surely getting it done. |
The other gaps are fair. It's surely won't be a show truck but I would like to make it fit as well as possible. I've got to much time invested to not do it right. I'd like to know how some other nice fits look. How much gap should be between the fender and rocker ? Should the fender touch the rocker ?
1961 crewcab
also I don't think gm's standards for trucks were as high as we put our standards today...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Look at the thread of pictures this forum has. I am going though a similar thing as well. I went through alot of pictures this last year to get info on alignment of doors,rockers, and fenders. From my picture collection, they are supposed to be in-line vertically at the front. Unless you spend alot of time, there is some mismatch. I would post a pic, but im not sure how yet. Look through the picture thead.
Tom |
....did it work? yes it did, i posted my first pic...lol Last edited by rideblue00; 11-03-2010 at 08:08 PM. |
When ever I restored my last camaro ot even this truck we used painters mixing sticks to set the gap, they are the right thickness as far as the door gap, fender should line up with the rocker end point... with about a 3/16 gap to door.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Good luck Mr. Phelps.....
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Aero, you are a wealth of awesome information. Thank you for all your input. I always learn something!
Thanks for the pic's guys. I'm going to finish the body work on my hood and front fenders to get my mind off of it for a little while and come back to it later. When I get frustrated I have to do other things for a while to let my nerves settle down.
Be sure your hinges aren't sloppy as well. If they are, it will really make alignment difficult.
Thanks, we rebuilt the hinges before we started trial fitting. I guess if all else fails I can shorten the rocker to match the door if that makes the fender and everything else line up properly. I will check everything possible and get several sets of eyes on it before I rush into anything though.
But Found Her 25yrs Later!
I noticed in another thread that a member was having trouble lining up their doors.
A little tip that might help those using the same doors on the same cab is to trace around the mounting hinges. Perhaps make permanent marks in the metal so they still can be seen after paint. I re-hung my doors today and just lined them up with the outline of the hinges and all is as before. Posted via Mobile Device
or drill a 1/8" hole through the hinge and it's mounting surface before you disaasemble. you then just need 1/8 line up pins to put it back in place
ron |
#15 |
Drilling an 1/8" hole before dissasembly helps a ton to get the sheetmetal back in place when it's time to put everything back together. If the gaps are still uneven, you can weld 1/8" welding rods on the edges of the panels to close up the bigger areas. I made a "how-to" thread over in the body/paint section that shows the process.
http://67-72chevytrucks.com/vboard/s...d.php?t=497761 Here's what can be accomplished with enough time and effort. ![]() ![]() ![]() ![]() ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#16 |
meowMEOWmeowMEOW
^now thats called giving a crap! Huge effort man, impressive.
I've got my doors off now, and have been avoiding thinking about the eventual alignment.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#17 | |
#18 |
Put in weatherstripping first, as it will tend to push the door out in some ares.
