Old 11-04-2010, 08:48 AM   #1
raycow
Re: Help finding Input Shaft Bearing for 3 speed
If you have the HD Muncie 3 speed, the GM designation for that is SM330. It has a 7 bolt side cover and is often confused with the much more common Saginaw (SM326) which it superficially resembles. As you have found out for yourself, its parts do NOT interchange with the Saginaw.
The .040" shim between the thinner bearing and the gear should be a workable fix, but I am surprised that your bearing house can't interchange the NDH number.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-04-2010, 09:27 AM   #2
dznucks
dznucks's Avatar
I actaully have two of the Muncie's and a Saginaw in the shop.
The two muncies were built several years apart and use the exact same bearing. That's why I find it hard to believe its not easier to find the right bearing for this tranny.
dznucks is offline   Reply With Quote
