Old 06-16-2003, 11:05 PM   #1
KEH
Better late than never
KEH's Avatar
Brown wire?
What is the short brown/white wire in the engine harness that is the above fuse box terminals? I'm looking for somewhere to tap into for my electric choke, but this wire is not hot anyway. Any ideas? Thanks
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 06-16-2003, 11:37 PM   #2
jewels.
jewels.'s Avatar
you might try checking out these wiring diagrams to see if this will help you. (if i suggested something for you, it would simply be from studying these diagrams)
Wiring Diagrams
good luck!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 06-16-2003, 11:42 PM   #3
Gee_Emm
I think that might be for the proportioning valve, does it have a boot on the end?
Gee_Emm is offline   Reply With Quote
Old 06-17-2003, 12:10 AM   #4
SEVEND2
SEVEND2's Avatar
does it end up right behind your brake booster?
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 06-17-2003, 12:27 AM   #5
KEH
KEH's Avatar
It only has 6" reach, with a female connector & no juice in any ignition position. This is a new b&h harness, but I know I've seen this on other trucks (most are tucked into the wire gutter). Before posting I looked at the wiring diagram & it looks like it comes off the heater fuse terminal. Anybody know?
Old 06-17-2003, 12:33 AM   #6
SEVEND2
SEVEND2's Avatar
I know the wire your talking about, i dont have mine hooked up, If i can rember right.... it went to the emmisions controler for Smog on my truck
and stage 2
Old 06-17-2003, 08:36 AM   #7
bpmcgee
bpmcgee's Avatar
I believe that Sevend2 is right, I have a short wire there that went to the smog components. My wire, on the other hand, is hot with the ignition on and dead otherwise.
KEH, Is it possible that you mistested something or there's a fuse out that might cause this reading? I used this in the past for my electric choke, and I'm now using it to trigger the relay for my TBI computer with no problems.
Good luck,
Brian
bpmcgee is offline   Reply With Quote
Old 06-17-2003, 10:15 AM   #8
fatfords
fatfords's Avatar
Brain and SEVEND2 are correct. The wiring diagram for the '72 shows this as one of the wires going to the TCS solenoid, that is part of the emissions package. I believe it goes to the fuse panel and is marked "radio/TCS". Like Brian said, it should be hot with the ignition on. I am using mine to lock up my 700R4 torque converter clutch.
Good Luck,
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 06-17-2003, 12:45 PM   #9
SEVEND2
SEVEND2's Avatar
Ah yes, It does ring a bell for me, but it was not a consistant 12 vt for my electric choke, so i did not use it. (i metered it out today and it jumped from 13.5vt to 9 vt back and forth) the carb book says it need to be a constant for the choke) I would just tie it off for dead unless your running emmisions
and stage 2
Old 06-18-2003, 02:36 PM   #10
garthdader
The brown wire is for your brake proportioner. For my electric choke I hooked it up to my old points distibutor wire. This is assuming that you are converted to HEI. It is hooked up through the ignition switch and is a hot wire. Hope this helps. Just look at the wiring diagrams and all of your questions will be answered.
garthdader is offline   Reply With Quote
Old 06-18-2003, 09:53 PM   #11
KEH
KEH's Avatar
garthdader,
The prop. valve is the light brown wire. The wire I'm talking about is dark brown. Anyway, I hooked the choke to the fuse box.
