Old 11-05-2010, 02:02 PM   #1
cpisani70@aol.com
cpisani70@aol.com's Avatar
Hei
68 K-10 upgrade to HEI what do i feed this dist. with i have heard the original wire doesnt supply enuff voltage can anyone help with this?
cpisani70@aol.com is offline   Reply With Quote
Old 11-05-2010, 02:21 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Hei
Try this
http://rmcavoy.freeshell.org/HEI.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-05-2010, 04:21 PM   #3
gary2232
Re: Hei
This topic has many threads that will help you here is one.http://67-72chevytrucks.com/vboard/s...ad.php?t=13698 You can also do a search and find so much info on HEI that it will make your head spin. Always check the FAQ section the information is endless!!!
gary2232 is offline   Reply With Quote
Old 11-05-2010, 08:57 PM   #4
lt704
Re: Hei
Massachusetts checking in. This group also helped me correct my voltage on my converted HEI. Friends outside this group cannot believe the support our group offers. Good luck
lt704 is offline   Reply With Quote
Old 11-05-2010, 09:05 PM   #5
shiner2001
shiner2001's Avatar
Re: Hei
I run a 10-12 gauge wire from the fuse block to the HEI. Any switched 12V will work. Double check that it's hot in start, not just run. And triple check that it's not a constant 12v, that will fry the coil.
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 11-05-2010, 11:14 PM   #6
Ronnny
Re: Hei
I just did my truck. with it in the run postion you only get 6-9 volts i can not remember well. Was a yellow wire. I followed it back and in the plastic above the firewall it came together with another yellow wire and turned in a piece that look sort of like glass coated wire used in high heat places. I cut it back to there and seems the resister was somewhere in there cause i started reading 12 volts at the end of the wire. So spliced from that point to the wire i cut off when i got my hei from the yard i was at. My truck is a 68.
Ronnny is offline   Reply With Quote
Old 11-06-2010, 12:08 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Hei
It's all in the link I posted.
VetteVet
