Old 10-30-2010, 08:07 PM   #501
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
I decided not to do bags too much money to do it wright
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-30-2010, 11:25 PM   #502
flamingbig10
6.0 powered square
Re: my 80 build
well got the part of the black paint on the frame will flip it over tomorrow and paint the other side
Aaron
Old 10-31-2010, 11:36 AM   #503
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 11-04-2010, 11:55 PM   #504
flamingbig10
6.0 powered square
Re: my 80 build
If it goes well I plan on moving the frame to garage either tomorrow or Saturday to assemble it
Aaron
Old 11-05-2010, 10:24 PM   #505
flamingbig10
6.0 powered square
Re: my 80 build
I was able to get some help and moved the frame to the garage so it should be a roller tomorrow
Aaron
Old 11-06-2010, 08:51 AM   #506
JohnC
JohnC's Avatar
Re: my 80 build
Sweet!
JohnC is offline   Reply With Quote
Old 11-06-2010, 09:05 AM   #507
SCOTI
SCOTI's Avatar
Re: my 80 build
Keep @ it.
Food for thought.... you've been driving it super low for a while now & if you're anything like me, it won't be the same w/minimal drop. A 4/6 drop is a great compromise for everyday driving w/o worry (you can even get a little more a-arm clearance if the x-member is notched).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-06-2010, 04:36 PM   #508
Puglia10
Re: my 80 build
looks good man!
can you put up some pics of it now/as a roller, especailly of the a-arms and crossmember (mostly front end stuff) im putting mine back together and need some pics for reference, thanks!
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 11-06-2010, 06:31 PM   #509
flamingbig10
6.0 powered square
Re: my 80 build
I did it its a roller took a little wile since every bolt and nut had messed up threads, luckily I had the tap and die I needed, and all the red and rusted parts will be swapped from my truck if any one wonders
Aaron
Old 11-06-2010, 06:36 PM   #510
flamingbig10
6.0 powered square
Re: my 80 build
Originally Posted by Puglia10 View Post
looks good man!
hows this
Aaron
Old 11-08-2010, 01:27 AM   #511
Puglia10
Re: my 80 build
youre the man, thanks!
1979 c30 3+3 dually
1946 GMC
Old 11-10-2010, 01:14 AM   #512
flamingbig10
6.0 powered square
Re: my 80 build
no problem
Aaron
Old 11-10-2010, 01:24 AM   #513
flamingbig10
6.0 powered square
Re: my 80 build
today I cleaned up and painted the brake lines aluminum but I think I'm going replace them with new ss lines, and may I have decided on a cam a texas speed 228
Aaron
Old 11-10-2010, 01:34 AM   #514
nbpro
Re: my 80 build
looks good
nbpro is offline   Reply With Quote
Old 11-10-2010, 11:02 PM   #515
flamingbig10
6.0 powered square
Re: my 80 build
thanks
I pick up some new grade 8 hardware for the motor mounts that mount to the frame and new replacement motor mounts but I believe I'll sent them back because I bet they what last to many 3000rpm launches
Aaron
Old 11-11-2010, 10:21 PM   #516
flamingbig10
6.0 powered square
Re: my 80 build
well I just ordered brand new stainless steel brake line kit and new clips, and might be ordering the cam, push rods, and springs tonight
Aaron
Old 11-12-2010, 02:13 AM   #517
flamingbig10
6.0 powered square
Re: my 80 build
felpro top end gasket kit and timing chain gasket kit
leaf springs bushings
I got the motor mounts split apart now I need to blast and paint them and install some poly mounts
new front shock mounts
Aaron
Old 11-12-2010, 02:17 AM   #518
flamingbig10
6.0 powered square
Re: my 80 build
I painted the factory brakes line silver but will be replaced by stainless steel lines
I'm replacing any bolt that deals with the motor to the frame with new grade 8 hardware
Aaron
Old 11-12-2010, 10:10 AM   #519
menace121978
menace121978's Avatar
Re: my 80 build
looks great Aaron!! your going to love the ls swap. i love how your going back through and just replacing everything. this is going to be the build to watch!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 11-12-2010, 12:17 PM   #520
JohnC
JohnC's Avatar
Re: my 80 build
I agree man. Now is the perfect time to pay attention to the little things.
Old 11-12-2010, 08:03 PM   #521
flamingbig10
6.0 powered square
Re: my 80 build
I want every thing to be right the first time around, its going to take a little more money than I wanted to spend but at least I only have to do it once.
Aaron
Old 11-12-2010, 08:37 PM   #522
flamingbig10
6.0 powered square
Re: my 80 build
well I bought the cam http://www.texas-speed.com/shop/item...d=167&catid=44
Aaron
Old 11-13-2010, 03:16 PM   #523
flamingbig10
6.0 powered square
Re: my 80 build
Now I need to get a ls2 timing chain there built better and stronger, h3 oil pan for extra clearance, corvette fuel filter and braided fuel hoses and fitting
Aaron
Old 11-13-2010, 08:46 PM   #524
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
Originally Posted by flamingbig10 View Post
choppy or smother idle did you go with?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-13-2010, 08:51 PM   #525
flamingbig10
6.0 powered square
Re: my 80 build
choppy
this what it sounds like in 6.0 gto
Aaron
