![]() ![]() Join Date: Jul 2002
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Beautiful work so far. I am really enjoying your build.
Lucky Teter at the wheel
Remember the 100 dollar cabs I got? Well they came with doors too which I need to steal something off of. Measured 3 or 4 times on the drivers side only to cut it an eighth inch too short. DOH!!! Some surgeon I am. Passenger side I drilled out the spot welds and removed a good bit into the door. I'll just plug weld the holes at the bottom and butt weld at the top frame.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
Bottoms of these doors were swiss cheese, so I didn't feel bad stealing the window frames. The Blue and white cab that they came off of was also totally gone on the bottom. Someone had repaired it with newspapers stuffed in the rockers with bondo liberally spread on top. Really nice, long lasting repair. The fun part was the small fire when the plasma cutter hit the newspaper layer. It was very helpful when I was cold that day. At least I could use the newspapers to date the repair, Oct 7, 1992.
Onto trying to weld air on the drivers rear window channel, yeah that's not gonna work. I had to cut and weld in the eighth that I was short. Wasting time, but it worked fine.
#4 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Green truck is now donating more sheet metal to the patient on the operating table. I'll be getting rid of my old inefficient heat and air system in favor of a new one, so a new firewall is in order.
Here is another opportunity for a solution. The burb roofline has a very slight pinch waist as it continues to the rear, a truck does not. So I encountered a little problem of the drip rails not meeting up just right. I decided the best way to attack this issue would be simply to slice off the drip edge, weld in a tiny strip of metal, and grind it all smooth. The drip rail gets a liquid caulk on top which also helps cover up where I welded the roof back down.
Semi finished on this side.
