Gauge Cluster
Hello All I'm new to the form, I have a 1964 GMC SW Daily Driver project,
![]() Looking for Ideas on what some of you have done to your Gauage Clusters, got any pictures you can show me/Us thanks P1glet Gresham Or |
Senior Enthusiast
Re: Gauge Cluster
Welcome to the forum. Here are some earlier threads that include GMC gauge panel ideas:
http://67-72chevytrucks.com/vboard/s...ht=gauge+panel http://67-72chevytrucks.com/vboard/s...ht=gauge+panel |
Re: Gauge Cluster
Thanks there are some great Ideas
P1glet Gresham Or |
![]() Join Date: Nov 2008
Re: Gauge Cluster
Welcome to the Board !!!
![]() Last edited by 62 Longbed; 11-04-2010 at 02:22 PM. |
Re: Gauge Cluster
I found that the GMC cluster was hard to find in AZ cracked, brittle and broken. I was going to use it for a mold anyways. However, I changed my thought and decided to go with all equus guages. I like them and not too expensive. It is amazing what $6 dollars can do for your dash.
![]() $1.00 for 1/2 MDF scrap $5.00 for patch of suede had a can of spray glue and spent about 45 minutes fabbing it up and cutting it. ![]() ![]() |
#6 | |
![]() Join Date: Oct 2006
Re: Gauge Cluster
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
![]() Join Date: Aug 2004
Re: Gauge Cluster
I bought Dolphin guages for my 65, then used a piece of 1/4" thick Cherry wood and made the holes for the guages, stained it and put it in with the stock restored bezel. Sorry I dont have any pics of my interior but I think you get it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Intentionally Left Blank
Re: Gauge Cluster
Here's mine. I just used some Lexan trimmed to fit like original gauge lens. I cut the holes where I wanted them and then painted the back with black paint. The tach hangs from a custom bracket made to fit in the old visor loacation.Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
#9 | |
Who Me?
Re: Gauge Cluster
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: Gauge Cluster
Rusteez how did you keep your cluster firm and in place
Re: Gauge Cluster
Same gauges as Rusteeze64GB just in stock bezel. I just haven't install them all yet.
Re: Gauge Cluster
Here it is...my '65 Chevy...
Re: Gauge Cluster
I shape the cluster the size of the total outside bezel size. then with the suede wrapped around it I just stuffed it in there. It is a super snugg fit. It does not pop out unless you reach around the back and pop it out. When I fit it in there I pushed from the bottom up and then pushed it in at the bottom. I hope that helps.
