#1051 |
Re: What did you do to your truck today!
Going out right now to see if my just, received caddy rear disc brake brackets fit...
#1052 |
![]() Join Date: Jul 2000
Removed A-arms, shafts, and ball joints. Massive torque and 1-5/8" socket required to loosen the lower A-arm shaft bushings. Lower ball joints were a piece of cake using my handy-dandy ball joint press. Probably spent more time popping the tie rod ends loose.
Hope to get at least the upper A-arms cleaned-up, painted, and assembled tomorrow. Using Moog parts that were made in the USA back in the late 90s. Sadly, I'm not sure they're still made here. The fun of it all! ![]() ![]() ![]()
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 11-06-2010 at 09:50 PM. |
#1053 |
Master Procrastinator
[QUOTE=MikeB;4281314]Removed A-arms, shafts, and ball joints. Massive torque and 1-5/8" socket required to loosen the lower A-arm shaft bushings. Lower ball joints were a piece of cake using my handy-dandy ball joint press. Probably spent more time popping the tie rod ends loose.
Hope to get at least the upper A-arms cleaned-up, painted, and assembled tomorrow. Using Moog parts that were made in the USA back in the late 90s. Sadly, I'm not sure they're still made here. you are lucky, I broke multiple ball joint forks on the passenger side lower, finally gave up and torched everything, good thing I had CPP spindles en route, just slapped my final POR15 coat on the frame and rear axle, and degreased the brakes now a little dry time and back out to paint the whole setup ![]()
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#1054 | |
yes, i do
Hey mikeb, what does your balljoint press look like? Posted via Mobile Device
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#1055 | |
![]() I removed my exhaust from the headders back, shortened the pipe to and installed and welded in new mufflers, have the pipes routed out to front of the rear tires for the time being but ran out of daylight so will finish the hanging and welding tomorrow. when money allows i'll have a muffler shop route some new tailpipes.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1056 |
my son and i put a new engine in my new 1968 suburban . got it running and my son took it for the first drive ! he was smileing ear to ear !!he hates working on cars/trucks but he helped me get it done. i enjoyed the time spent with him alot. he turns 30 on monday so happy birth day son !!!
#1057 |
Sofa King Crazy!!
Took my truck to it's first big show!! Met a board member too, 72SWBchevy in the pic.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() Last edited by Slick67; 11-08-2010 at 11:22 AM. |
#1058 |
![]() Join Date: Jan 2006
Slick67 - That's one nice looking truck!!
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
#1059 |
![]() Join Date: Nov 2008
today i painted my 8" bed via dupli color rattle cans lol dont have the cash for the body shop dont have hvlp guns or expensive wish i did pics coming soon. wanted to get some paint on it before the bad weather came here in Mass.
#1060 |
Sofa King Crazy!!
Thanks dhaymaker!!! Took a while to get it that way!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#1061 |
I finished putting on an edelbrock 600 carb and performer intake. Unfortunately I found out the the floor is rotten right under the gas pedal while adjusting the carb linkage.
#1062 |
Got my 72 GMC Short Fleet back from the Mechanic.
Had all new Vent/AC Tubing put in. Then had a remanufactored AC Compressor put in, new Hoses, a new AC/Heater Switch Housing, Cleaned up the Wirring under the Dash, Fixed the Reverse Lights, put on the new Billet Aluminum Gauge Bezel and installed my Pro Comp Gauges. Getttin her ready to go from Northern California (was 50 Degrees Today), to her new Home in the Palm Springs area (it was 80 Degrees THERE today)! ![]() ![]()
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#1063 |
looked at it, and decided that I had too many other things that were priority. made me sad. ended up finishing early so pulled off the drivers side bed side got it ready to take to the scrap yard (was badly damaged before I got it) getting the spare I6 ready to swap in I CANT WAIT!!!
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck ![]() TROUBLE MAKER RACING ![]() "If you can't stand BEHIND our troops, please stand in FRONT of them." |
#1064 |
yes, i do
got with nickp51 and went to the pull-a-part and helped him pull an aftermarket cruise control unit, hei dizzy, and wiper delay for his truck. then he helped me pull a wiper motor from the truck that he got the wiper delay from, the nova that we got his cruise control and dizzy i got another wiper delay(the exact same one actually), and a brake booster and master cylinder from a 4x4 square body that i will be putting in my 72. and he let me borrow his welder and i got the driver's rocker ugly-welded back in place, but now i don't have to use the 2x4 that i had jammed between the cab and bed
#1065 |
Kill Bill...et
Installed my c-notch today. Casualties: 1 step drill bit, two 1/2" drill bits (one trying to drill out the said step drill bit), two drop lights, and one work shirt eaten by my angle grinder. I did prevail!
![]() ![]() ![]() ![]() ![]() And if a suspension weren't required.... ![]() Last edited by stevencvn72; 11-08-2010 at 03:42 PM. |
#1066 |
Dude...I'm a CHICK
Justin and I got the tranny gasket and filter changed out, what a mess! Also got the rest of the AC unit removed from the engine compartment, then started removing all my seat belts, went to find a couple others and started finding all manner of things that need to be cleaned, painted, installed etc..etc... geeze, just got my work bench cleaned off and now I have a whole line up of stuff for tomorrow, lol
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
#1067 |
RAT1968 '68 Cab/'71 Parts
I was sitting here thinking I didn't really get anything done, when I started counting what I did on my fingers. When I needed thumbs and a few toes, I changed my mind as to the progress today.
It started out as a bummer. Rain curtailed any thought of painting parts or anything. I climbed under and bolted up the TH350's torque converter to the flex plate. Not fun with only one guy. Then I connected the front brake line from the proportioning valve. Only to find out the next line (that crosses over to the LF disk) had a hole rubbed in it. Pulled that. Hooked up the '68 throttle linkage to the firewall, since the '71's wire was too short using the '68 cab. I had ordered a IL6 threaded rod to make it from the throttle linkage to the carb. Now, I just have to figure out how to hook it to the Performer carb. Oh, yeah. The 1" spacer for under the carb is back-ordered at Summit until 11/17, so I have to wait anyway. Installed the new brake pedal pad and trim, and snapped on the new excel. pedal (and trim) ....I'm early on this, as the cab's still stripped. But I wanted to see something "sparkle" today. Thanks to the info from someone on the Forum, I decided to pull the valve cover and put a baffle in over the PVC valve. Used the harmonic balancer puller to pull off the ratty steering wheel. It was cool stock, but beat to crap. So, I cut the hell out of it to get at the hub, which I'm modifying for the $50 wheel I got on EBay... Okay...I can post a couple of pictures of that mod in progress. Lots of grinding, etc. I called the guys at ECE to check on my wiring. It's a special order deal. So it'll be here soon (lights and engine compartment). Went to the P.O. and picked up a few parts, including a liquid-filled fuel pressure gauge. Called the Mfg in Anaheim, CA just to check the install. Nice folks. Opened some other parts that came via the Brown Army. Then I opened my Master Charge bill. Looks like the paint has to wait for a while....Yetch!!!!!
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 11-09-2010 at 01:32 AM. Reason: I'm stupid |
#1068 |
Ahhh, the retired life. Took care of the house today and then went to the shop to finish up plumbing the fuel supply.
Left my camera at home again!!! But when I came home, I brought the dash with me for the semi-final set up of the tach. It looks like I'm running at just under 2000. But I'm standing still. Maybe all the banging around? Anyway, my M/C "club" colors got "wired in" and I went for the black and white look. If I didn't break something, I'm done with the dash.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#1069 |
Grandpa in the rustmobile...
Dash looks good!
Drove mine today to school and back, not leaking water yet ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#1070 |
Got my stainless bed bolt kit from Mar-K today. Bolted everything up for a dry fit
[IMG] Hope to take it apart tomorrow and drill the offset washers holes and trim the edges to slide the bed strips into. Ambitious? Yes...I think so. Had a hard time findind the boards long enough to cut the 7 7/16ths boards so had to make due with 7 1/4's. Just means I have to custom cut each bed strip depth. The things we do for our trucks! Cold today and supposed to snow so we'll see how it goes tomorrow.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 11-09-2010 at 10:48 PM. |
#1071 |
^^who I am^^ what I say>
I cleaned out my double pumper and replaced on the truck. I think I have the flooding issue fixed, hopefully.
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
#1072 |
Well, Got the bed tore back down and the offset washers countersunk. I will try to cut the channels for the bed strips tomorrow. Still pretty happy with the progress today.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#1073 |
![]() Join Date: Jan 2009
I got PAID to put my tranny back in..........
my boss did my transmission and he had me put it in today.......supposed to test it tomorrow
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#1074 |
A little more work in the "engine compartment". Fabbed a hub for the Italian steering wheel.
Connected the trans filler to the firewall. Mocked up the Vintage Air firewall cover. Covered a few hoses with carbon fiber mesh. Got the throttle linkage working. "Finished" plumbing the fuel line between the fuel pump and the carb. Can't tighten any of this stuff up, 'cause the carb/intake spacer is still on back-order. Mocked up the engine wiring harness. Have to change out the purple eye for a spade for the starter I'm using. Anybody have pics of the way they routed the + battery cable to the starter? All-in-all, a good day.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 11-11-2010 at 07:31 PM. Reason: Slippage |
#1075 |
Replaced the vacuum advance and some hose. Fired her up and backed it up the driveway
