#1501 |
VA72C10
![]() Join Date: Mar 2008
Re: PO has me PO'd
Interior looks good!
#1502 |
![]() Join Date: May 2006
Re: PO has me PO'd
Thank you, kinda went with the spartan look. Still want to find a good rubber mat when they make a good repro. Doors are next to be painted by Maaco
#1503 |
Re: PO has me PO'd
#1504 |
Can't wait to retire!!
Re: PO has me PO'd
The seats look great Jim! Way to go on the progress.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#1505 |
Back in the sticks
Re: PO has me PO'd
[QUOTE=jaros44sr;4240582]got the seats recovered, what a 8 month ordeal that was, that story could be a novel, most unpleasant part of the restore so far!!!
changed the hot air choke over to electric, pretty simple and straight forward. Just switched out the guts w/ one screw Ol' Faithful...God Bless America QUOTE] Nice Seats and console! I need to do the choke thing to mine too. Just need to run the wires, but I'm having too much fun driving it!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#1506 | |
Re: PO has me PO'd
3x on the manufactorer(but all corrected by them, 4x didn't even tell them about it. seems that their 'exact match to the original' has an extra 6 vertical rows that the original does not. Found this out from the installer, he didn't bother to tell me until after the seats were all sewn up. cost me 30 bucks to ship the original seat matrl. out to them, so they could make sure it matched!! shipping wasn't bad, they said 5 weeks, and they shipped within 5 weeks
installer jerked me around on the price, increased it 3x. borderline bad business The only 2 positives were the 2 board members, 6T727T2 and low and slow. They were both great to deal with Thanks Tim, how are u doin'??? [quote=red71cheyenne;4241081] Quote:
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-14-2010 at 08:30 PM. |
#1507 |
Back in the sticks
Re: PO has me PO'd
Don't worry, you'll get there. It took me almost 9 years!
#1508 |
Re: PO has me PO'd
WOW!!!< great news, I only have 4 more to go
Seriously though, I am enjoying the work. What else would I be doing with my time
#1509 |
Back in the sticks
Re: PO has me PO'd
How are you going to wire up your choke? I know the red is going to go to power, but how about the other one? Does it just go to ground? What decides if its on or off?
#1511 | |
Re: PO has me PO'd
when you find out how it works give me a call thanks J, nice progress on your truck, looks great
#1512 | |
Back in the sticks
Re: PO has me PO'd
#1513 | |
Re: PO has me PO'd
My HEI is hooked up to the ignition
#1514 |
Back in the sticks
Re: PO has me PO'd
Mine is too, got a plug from the junkyard and just replaced a wire in the bulkhead connector for it. The relay idea is a good one for that, will ensure you get full voltage at the choke.
#1515 |
Re: PO has me PO'd
Here are the newest addition to the mods and parts to the project...
didn't like the console that came with the B&M shifter, so I changed to Lokar, boots and rings seem to be a better fit. Trans, cooling lines came from In line Tube. Now, just need some time... ![]() ![]()
#1517 |
GEARHEAD
Re: PO has me PO'd
I like those lokar rings a lot!
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy)HG's Plow Truck '78 K35 DuallyBigass Farm Truck HG's thread of miscellaneous stuff |
#1518 |
Truck and auto performance nut
Re: PO has me PO'd
so does that shifter have detents for positive 1-2 and 2-3 shifts? Or could use easily overshoot 2nd and hit OD or even N?
A buddy is offering me a 2nd gen f-body shifter...it would just need a console of some sort. Even though its OEM...those shifters had detents (apply right pressure to shifter while moving forward forced lock into next detent) so you could slam 1-2 and 2-3 w/o hitting N.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#1519 | |
Re: PO has me PO'd
thanks J, I'm enjoying your build progress
they were one of the reasons I went Lokar, planned on putting them side by side, but they don't quite fit. So, I will buy 1 more and bend the outside edges down to fit the contour of the hump, then cut the LED surround and mount it on the top of the 2. unless I get another idea Quote:
I'd say go for it!! Sounds like a better shifter for your needs
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-07-2010 at 10:44 PM. |
#1520 |
Re: PO has me PO'd
I had been thinking of going with a B&M Truck Megashifter. I want to get away from the column shift because it won't be as accurate as I will need for burnouts, shifts during passes, etc. I'm not pleased with the look of the Megashifter...but its more about function then appearance.
Now....if their Unimatic shifter or this Lokar gave me positive upshift detents...I'd go that way.
#1521 | |
Re: PO has me PO'd
#1522 |
Re: PO has me PO'd
Way to keep pluggin' along there bud.
![]() Looks like it could be a happy spring time for Jim this year.
#1523 | |
Re: PO has me PO'd
![]() the work to be done list is getting shorter, and the parts list is getting shorter! Actually, I'm looking forward to another winter in the warm workshop, not much happening around here except a fishin' trip/ snowmobiling in Feb. Presidents Day, if you are around...
#1524 | |
Re: PO has me PO'd
BTW: I have been lovin some of the pic's you have been posting like the view fron your front door ect.. I miss the country life, went to the metropolis to make a living.... Been to Old Faithfull a couple times myself too.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1525 |
Re: PO has me PO'd
Picked up some ARP flanged bolts for the pan, and another ring for the shifter, looks like I will have to build a box to mount the LED selecter to the hump, and maybe cut a 1/2" outta the t/c ring
yeah, I know, I got some more grinding to do (first pic) ![]() ![]() Here ya go Swamprat, I can see why you would miss a place like this drove up above the tree line, there was a fire in one of the states at the time, or you would be able to see much farther ![]() Big Sky is just to the left, picture taken just before I fell in the river(Galleten River) ![]() Aftermath, first time in 20 years I fell in! Water was only a foot and a half deep, but when your prone....well it was over my head ![]() Weird lookin' cows out there ![]() local story out there goes something like this: Husband decides to take his wife elk hunting with him. Sets her up in a good spot, and about an hour later hears a shot. walks down to her spot to hear her yelling and screaming at a man standing near, with her gun aimed at him! "Stay away from my ELK"...Man's response was "No problem, lady, just let me get my saddle off"
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-12-2010 at 04:47 PM. |
| Bookmarks |
